Author Topic: DDS vs TrueArb, something is wrong? or DDS is no go for timing sensitive signal  (Read 4735 times)
Offline RoadRunnerTopic starter
I was trying to generate UART signal with only 1200 Baud. i have used Siglent easywave software with my SDG2000X to genrate a UART packet with around 5M points in DDS mode at first , and i found out the signal high low timing is just no consistent though the signal.  Then i change it to TrueArb mode and everything was just fine.
whole packet transmission is "almost" same in both case , it just individual bits which does not seems be following the timings .
a document from keysight provide a descent reference to compere between DDS and truearb. http://literature.cdn.keysight.com/litweb/pdf/M8190-91050.pdf
 Please take a look at attached images.
« Last Edit: May 07, 2017, 08:09:26 pm by Gaurav »
Offline awallin
If the DDS produces an analog sine-wave which then goes through a sine-to-square converter to get your output, then you can expect problems at low frequencies (you mention 1200 baud) because the slew-rate of the sine at zero-crossing is low.
I would guess the DDS is more meant for generating sine-wave, where changes in frequency or amplitude can be done fast but perhaps not every cycle.
Offline Electro Fan
Might be worth checking to make sure the latest firmware is installed:
http://www.siglentamerica.com/gjjrj.aspx?id=15
FWIW....
Siglent's 2.01.01.23R3 firmware dated 2017/3/23 says:
6. Fixed some bugs a) Arb Waveforms In DDS Mode Have One (Small) Glitch Per Cycle; some other items reference ARBs
Siglent's 2.01.01.22R5 firmware dated 2016/9/30 says:
2. d) Frequency Coupling/Phase Lock Does Not Work in TrueArb; some other items reference DDS and ARBs
FWIW....
Will try to update firmware and see if this makes any difference.
Offline pascal_sweden
  • Country: no
Just out of interest: Why are you using an AWG/DDS for generating a UART signal?
Why don't you use a cheap microcontroller and a 4x4 keypad to generate 16 different test sequences by the push of a button?
though no particular reason . I was just playing around.
I was initially using USB to serial converter but , i need to test how my receiver will behave when a noisy and "little" off baud rate signal is being fed into. i was already using my function gen Ch1 . so i just simply used CH2 for UART, i was lasy enough not to use MCU.
Offline Electro Fan
FWIW....
Just a heads-up; probably should read/investigate/consider this before updating the firmware:
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg1203573/#msg1203573
FWIW....
oops ,
i think for now , i am okey with TrueArb mode .
its better to wait a little if this problem associated with R23 version of firmware is wide spread.
Offline tautech
Hard to know what went wrong with Wolf's unit.  :-//
We've PM'ed about it and maybe it needed another restart after updating but I'm guessing.
I do know it had been improved to a 2122X, maybe that is/was the problem.  :-//
Offline Electro Fan
FWIW....
oops ,
Glad you saw that in time to hit the pause button on the update.  Let's see what happens with MrW0lf's unit.
