Author Topic: DC coupled High Bandwidth passive Probe  (Read 569 times)
Offline Andree HenkelTopic starter
« on: June 18, 2024, 09:42:12 am »
Hy, I am looking for a DC coupled high Bandwidth passive Probe.
Basically the 12GHz P20B from Auburn Technology is close to what I am looking for, but I would prefer DC coupling.
Any hints?
So far I found:
Rohde & Schwarz RT-ZZ80, but I guess it is very expensive (~5 or more of the P20B, I asked for quote)
900 "PicoConnect" Series of passsive Probes by PicoTech (~2 as expensive as P20B)
Online tggzzz
Re: DC coupled High Bandwidth passive Probe
« Reply #1 on: June 18, 2024, 10:53:16 am »
My definition of "high" is 100kHz, so virtually all probes will be OK.
Alternatively, replace the adjective with a number :)
Search terms "resistive divider probe" "Z0 probe".
I have several HP10020A probes, and like them :)
The following users thanked this post: Andree Henkel
« Reply #2 on: June 18, 2024, 11:01:25 am »
Ok, more Detail of desired Probe:
Bandwidth 5GHz or above
Division 10:1 -> 450Ohm tip resistor
or Division 20:1 -> 950Ohm tip resistor
preferable DC coupled
« Last Edit: June 18, 2024, 11:03:08 am by Andree Henkel »
Online tggzzz
« Reply #3 on: June 18, 2024, 11:17:59 am »
HP54006A 6GHz.
Tek P6150 9GHz
« Reply #4 on: June 18, 2024, 11:49:33 am »
Ah, ok both seem to be discontinued, that´s why I didn´t find them at tek / keysight product pages.
But they are both available at used test equipment vendors.
Online RAQU_PL
« Reply #5 on: June 18, 2024, 09:05:21 pm »
Andrew Zonenberg has created few open source probes including Z0. It is called AKL-PT1 and has over 6 GHz BW.
They seems to be out of stock but You can contact him or DIY.
https://www.antikernel.net/products.html#passive
https://github.com/azonenberg/starshipraider/tree/master/boards/probes
« Last Edit: June 18, 2024, 09:27:30 pm by RAQU_PL »
The following users thanked this post: hpw, Andree Henkel
Offline hpw
« Reply #6 on: June 19, 2024, 07:38:21 am »
Looking forward for the Differential Probe 8)
The following users thanked this post: RAQU_PL
Offline calibrationfixture
« Reply #7 on: June 25, 2024, 06:27:44 am »
Hi Andree Henkel,
" Bandwidth 5GHz or above
  DC coupled "
PSPL 5520C Voltage Pick-Off. 20 GHz BW with 1:10 Attenuation. DC-Coupled. A cost effective alternative to Tektronix P6150 + 013-0251-00/01 and P6156 + 013-0237-00 combinations.
Calibrationfixture
« Last Edit: June 25, 2024, 06:36:37 am by calibrationfixture »
