Author Topic: Datron Wavetek 1281 and 1271 Firmware Revision levels?  (Read 1083 times)
Offline volvo_nut_v70Topic starter
« on: July 17, 2020, 03:25:11 pm »
Going by XDEVs excellent 1281 article, the 1281 seems to have Rev 3.12 as the newest firmware, the 1271 Rev 2.10
Has anyone have or seen anything newer?
Offline Arhigos
  • Country: gr
Re: Datron Wavetek 1281 and 1271 Firmware Revision levels?
« Reply #1 on: February 26, 2021, 05:20:30 am »
yes. mine is 3.14
Offline TheSteve
  • Living the Dream
« Reply #2 on: February 26, 2021, 06:19:48 am »
yes. mine is 3.14
Can you please dump the firmware eprom's and share it with us?
VE7FM
Offline Arhigos
  • Country: gr
« Reply #3 on: February 26, 2021, 07:01:04 am »
yes. mine is 3.14
Yeah, sure. But from Xdevs website it seems like i need some sort of custom eeprom adapter, right? Do you know if there is any easier way to dump eeprom, maybe with arduino, or thru GPIB?
Offline TheSteve
  • Living the Dream
« Reply #4 on: February 26, 2021, 07:23:44 am »
yes. mine is 3.14
I know it is possible to backup the nvram via GPIB, but I've seen nothing that suggests you can also dump the main firmware. I'm thinking you'd need a proper eprom reader. Older 1281's tend to have four 27C512's, newer units have two 27C010's.
Do you have an EPROM reader of any kind with a DIP socket?
VE7FM
Offline Arhigos
  • Country: gr
« Reply #5 on: February 26, 2021, 10:24:44 am »
yes. mine is 3.14
i have two 27C010.  I'm pretty sure i can find a compatible socket for that chip. Do you know what the easiest way to dump firmware without any special tools or programmers?
