I have 3000T series DSO.
Thinking of upgrading to MSO
Now I ran int these few questions that I seem to need some help with..
1: what's in the box?
3000T series data sheet has this to say about it:
- page 35, "(N2756A MSO cable delivered separately)"
- page 34 probe section, "N2756A 16 digital channel MSO cable; 1 per scope included on all MSO models and DSOXT3MSO"
My logic concludes that the 1350€ +VAT = 1620€ upgrade includes the N2756A probe set.
If not, disaster ensues since the total cost would become (1350€ + 760€)*VAT = 2532€
What's the story? Included or separate?
2: Separate monitor needed?
The main point in getting MSO upgrade is to work with analog and digital domain simultaneously on one UI/display. Otherwise a Saleae 16pro or similar would be much cheaper option, depending on needs (would do for me).
I've so far used 2 of 4 analogue channels for digital analysis and 2 for analogue ... with all the stuff on scope's display the screen real-estate simply runs out. It's difficult to discern what's where. Now I see need for 4digital + 4 analogue and soon up to 8 digital channels required.
Is the VGA option of any help here? Will mirroring the display on a much larger 24" screen make it much more visible, or is it hopeless due to WVGA res. limit of 800x480?
3: The verdict?
Considering the above, does it make more sense to go with a Saleae or some other similar product and save some money?
I've found analog-digital side.by.side quite useful. But if UI limit basically ruins this then
Thanks!
