Hi, gang,
I need to build several 8307-style log-based RF power meters, and I want to find an easy way to properly calibrate the 8307 units.
Years ago, when I had access to an RF lab, I'd simply connect the home-brew power meter to the calibrated output of a Marconi or HP (big buxx) signal generator, mark the appropriate meter deflection spots on the meter face, and boom!
I'd like to be able to do that again, and I was wondering whether the output of something like a 1032X is metered/adjustable, and how accurate it might be for my purposes. I am considering the purchase anyway, for RF generation and to use as a frequency counter (I have a 10-MHz SDO to "discipline" it).
I also have a Rigol 815 spectrum analyzer with tracking gen. I haven't looked into it yet, but I may simply be able to generate a tracking signal, measure it on the SA, and swap the SA input for the 8307 input to get the reading. If anyone knows whether this will work, please let me know.
Ten years ago I stopped buying radios and started buying test equipment. Now I obviously have to learn better how to use it to do specific tasks...
As always, thanks for your help.
Kirk, NT0Z
Rochester, MN
www.stealthamateur.com
