So I’m just learning about current probe Deskew fixtures…. Is this something that you should measure every time you use the same set of probes, or once you measure the skew with a specific set of probes is that somewhat of a constant latency? In other words, if I got access to a Deskew fixture and measured the skew time for my current probe, would that latency time be constant so I could apply it the next time I used the same set of probes?
It seems like the time skew would be related more to the circuitry and cable length than anything else. Though temperature probably plays a role, I’d guess it’s less of a variable than other physical attributes.
