Author Topic: Differences Between Brymen BM-257 and BM-829  (Read 43879 times)
Offline P90
Re: Differences Between Brymen BM-257 and BM-829
« Reply #50 on: September 22, 2014, 05:38:33 am »
And just for the record, I'm not complying, just stating my observations. I realize that most multimeters aren't going to measure up (haha, measure, LOL pun) to a Fluke, and I accept that.  :-DMM
Offline Lightages
  • Canadian po
« Reply #51 on: September 22, 2014, 05:41:46 am »
I don't find the autoranging that slow, as Franky has pointed out. I think this is down to personal taste. This is with my BM525.
Offline P90
« Reply #52 on: September 22, 2014, 05:48:12 am »
I understand. Lets just say it's not my slowest meter, but not the fastest. I guess my expectations were higher after reading all the rave reviews for Brymen multimeters. Perhaps most reviewers are moving up from cheaper meters, and are not Fluke meter owners, so they are not used to performance.
Offline Yago
« Reply #53 on: September 22, 2014, 11:14:11 am »
Is there any particular range or value that you are checking?
Just checked Volts with 1.4v cell and settle time was about 1 sec (BM857S).
Offline P90
« Reply #54 on: September 22, 2014, 11:52:19 am »
Check a resistor on auto range...
Offline Yago
« Reply #55 on: September 22, 2014, 12:20:15 pm »
About 1.5 seconds with 120Ohm resistor.
Offline unbiased
« Reply #56 on: September 22, 2014, 01:48:07 pm »
How "slow" is slow? Maybe there is more difference than just the colour of the holsters between these 2009 Greenlee's and the Brymen BM-829.
Here are some pictures of the insides of my Greenlee DM-830A that I bought. Maybe someone can show the insides of the Brymen BM-829 (or BM-829S) to compare.  Since the max upload filesize for pictures is limited, I have to post the pics in separate posts.  Here is the first set of pics:
You don't know what you don't know until you know it.
Offline unbiased
« Reply #57 on: September 22, 2014, 01:50:12 pm »
Here are some pictures of the insides of my Greenlee DM-830A that I bought. Maybe someone can show the insides of the Brymen BM-829 (or BM-829S) to compare.  Since the max upload filesize for pictures is limited, I have to post the pics in separate posts.  Here is the 2nd set of pics:
Offline P90
« Reply #58 on: September 22, 2014, 01:51:02 pm »
I just checked again with a 220ohm resister, and it's definitely closer to 2.5 seconds - seems like an eternity...      :-//
Oh well, it is what it is...
Again, I wasn't expecting Fluke quality from an Asian import...
Offline unbiased
« Reply #59 on: September 22, 2014, 01:53:12 pm »
Here are some pictures of the insides of my Greenlee DM-830A that I bought. Maybe someone can show the insides of the Brymen BM-829 (or BM-829S) to compare.  Since the max upload filesize for pictures is limited, I have to post the pics in separate posts.  Here is the last of the 5 total pics:
Offline unbiased
« Reply #60 on: September 22, 2014, 02:06:02 pm »
I just tried measuring resistors on the ohms auto-range on my DM-830A and it is quick at about 1 second average to show the value of a 50 ohm resistor.
It seems just as fast or faster when measuring a 3.6K resistor.
Did you try checking to make sure your maybe the 9v battery that came with it is old and weak?  Otherwise, maybe you got a bum meter.  I don't find it that slow.  It seems to me that it is a top notch quality meter easily equal to the flukes and especially at the price we got it for ($150.00 USD)!
Offline unbiased
« Reply #61 on: September 22, 2014, 02:27:20 pm »
I also just checked my Brymen BM-869S meter and the ohms auto range mode measuring 50, 3.6K and 4.7M ohm resisters is also pretty quick at just a bit under 1 second to 1 second. It is fast enough for me.
Offline P90
« Reply #62 on: September 22, 2014, 02:31:58 pm »
I replaced the battery first thing. Not that that should make a difference. The 869 is faster.
Offline unbiased
« Reply #63 on: September 22, 2014, 03:50:53 pm »
One thing I notice on this DM-830A daughter board is that it has two infrared LED's installed on it instead of just one like many other meters.  I take that to mean that it has a two way communications interface for when you use the USB attachment for running the PC software...?
You can see the two LED's mounted on the previous picture I posted in this thread above.
Offline Yago
« Reply #64 on: September 22, 2014, 06:32:55 pm »
The 857 is dissimilar too (50,000/500,000 count), perhaps not comparable.
Never looked at Brymen being a Fluke killer, just the price and features make them a very attractive alternative to the big "F" (in UK).
Offline kubroid
  • Country: cz
« Reply #65 on: February 04, 2015, 03:42:42 pm »
I'd like to know, if BM257 is a foolproof.
I mean, is it survive if i'll put probes into mains with ohm measurement selected. Or switch selector during probes in mains, or something like this.
Thanks!
Offline Lightages
  • Canadian po
« Reply #66 on: February 04, 2015, 05:36:32 pm »
No meter is foolproof. If you stick the probes in the wall socket on ohms range it will survive. If you do this with the probes in the current jacks the you will at least blow a fuse.
Offline kubroid
  • Country: cz
« Reply #67 on: February 05, 2015, 07:38:05 am »
Well, for me, most common measurements is voltage and resistance. Current is very rare.
So, most the time probes will be connected to voltage/resistance jack and only thing can go wrong - bad selector position.
In case BM257 it will be in Autocheck all the time.
And one more question - what is a "JACK" label above current jacks mean? Some beep warnings ?
Offline retiredcaps
« Reply #68 on: February 05, 2015, 08:14:11 am »
Be aware that when you are in Autocheck all the time, the input impedance is around 2.5k ohm at low voltage.  This means you may get incorrect readings.
As I wrote in a badcaps thread regarding the Fluke 113 and 12, they both have low impedance mode and how they can fool you into thinking there is no voltage.
http://www.badcaps.net/forum/showpost.php?p=315198&postcount=60
Yes to warn you have the probes in the incorrect input jacks.
Offline Rune
  • Country: no
« Reply #69 on: January 31, 2018, 05:12:28 pm »
I know that this is an old thread. Anyway if interesting somebody; Just now (until 15th March) is the BM829 on sale in Norway, and it is even cheaper than the BM257.
BM829 = NOK 1618,75
BM257 = NOK 1668,75
https://elma-instruments.no/nyheter-tilbud/tilbud/elma-bm-829s-sann-rms-multimeter-kat-iv-1000v.aspx
https://elma-instruments.no/produkter/elma-bm-257s-sann-rms-multimeter-kat-iii-600v-nrf-986123.aspx
