Author Topic: Calibration for HP 8901B Modulation analyzer  (Read 3737 times)
Offline MattSRTopic starter
« on: July 12, 2014, 12:10:56 am »
Hi Guys,
I recently purchased a lovely new (old) HP 8901B analyzer. From the bloke I bought it off, I know it was last calibrated 5 years ago, however I would like to get it done again. Does anyone know of any places to get it calibrated in Sydney, Australia? I did receive a quote from one place and they wanted $2,000 for it to be certified to NATA standards (whatever NATA is..)
Cheers,
Matt
Re: Calibration for HP 8901B Modulation analyzer
« Reply #1 on: July 19, 2014, 12:10:42 am »
Bump... Anybody? Surely someone in here knows of a place to get test equipment calibrated in Sydney..
Offline TheRuler8510
  • RF Engineer
« Reply #2 on: July 19, 2014, 01:21:27 am »
Ouch!...I got a perfectly good working unit off eBay last year for only $100, so it seems crazy to pay $2000 for a cal.
Why do you need it to be so precise? ...just curious.
"There are no facts, only interpretations."
--Friederich Nietzsche
Offline Alexei.Polkhanov
« Reply #3 on: July 19, 2014, 08:10:21 pm »
Did you see the Operation and Calibration Manual? http://cp.literature.agilent.com/litweb/pdf/08901-90113.pdf.
Brief look at the document tells me that most of function have self-calibration built in so you just need to follow the steps described. Also if you have RF signal generator and RF power sensor you can probably use that, I did not find references to any tools in a document however.
Online edavid
« Reply #4 on: July 20, 2014, 06:45:19 pm »
This is not a precision instrument, or a valuable one, and 5 years is not very long ago, and most cal labs are not going to be at all familiar with it.   Summary: Don't do it!
« Reply #5 on: July 22, 2014, 08:54:59 am »
Hi Guys,
Awesome responses, thanks for the help. I somehow missed the calibration manual which looks very handy. I have access to an up to date Aeroflex 3920 that gets an annual calibration done, so I will just use that to check the 8901B.
TheRuler - I can't believe you got one for $100 - wow!!! I'm using it to align and calibrate some digital radio equipment (APCO P25) and also to develop an open source version even further (using GNUradio and a USRP) I guess its not worth the cost and the DIY cal will be more than good enough.
edavid - That makes perfect sense, since I have the gear and now the manual to calibrate it myself, that should be more than good enough!
Thanks for the responses!
Cheers,
Matt
