Author Topic: Tweezers for low-impedance capacitors.  (Read 4141 times)
Offline tigrTopic starter
  • Country: ua
« on: January 19, 2018, 04:55:40 pm »
The measurement of low-impedance capacitors has always been of great interest in the environment of electronics lovers. Let's see how four meters measure low-impedance capacitors.
Rubycon ZLH Low Impedance 1000uF/35v.Max. impedance(100kHz)-0,017Ohm.
http://www.rubycon.co.jp/EN/CATALOG/E_PDFS/ALUMINUM/E_ZLH.PDF
Russian tweezers HB-14.
« Last Edit: January 19, 2018, 05:03:33 pm by tigr »
Offline BravoV
  • +++ ATH1
Re: Tweezers for low-impedance capacitors.
« Reply #1 on: January 19, 2018, 05:07:47 pm »
Are you asking which meters of yours is the most accurate one ?
  • Country: ua
« Reply #2 on: January 19, 2018, 06:13:05 pm »
No, I just restore justice. ;)
Offline tautech
« Reply #3 on: January 19, 2018, 09:00:48 pm »
Russian tweezers HB-14  :-//
Google can't find a source.
Link please.
Offline kirill_ka
  • Country: ru
« Reply #4 on: January 19, 2018, 09:14:13 pm »
Link please.
http://www.rlc-esr.ru/
http://rlc-esr.ru/index.php/pintset-nv14 (Russian-only)
I have an older model. Nice thing, really.
Offline tautech
« Reply #5 on: January 19, 2018, 09:27:59 pm »
Link please.
http://rlc-esr.ru/index.php/kupit
For ~$122 these are very well priced WRT the Canadian smart tweezers ST5.
Need to compare specs .......
Offline Shock
« Reply #6 on: January 19, 2018, 09:36:21 pm »
There is at least half a dozen on the market, if you stuff a $20 Atmel LCR clone into a small enough package you can own you very own brand as well.
http://www.smarttweezers.org/
http://www.lcrresearch.com/pro1/
  • Country: ua
« Reply #7 on: January 20, 2018, 11:56:47 am »
Capacitor Rubycon MBZ Ultra Low ESR for PC mother board  3300uF/6,3v.Max.ESR-0,012Ohm.
http://www.tetrix.com/products/32470/MBZ.pdf
« Last Edit: January 20, 2018, 12:00:05 pm by tigr »
  • Country: ua
« Reply #8 on: January 21, 2018, 01:22:36 am »
Let's see how it measures the capacitors in the circuit. I have already cited this example. The two capacitors are 2200uF 50V in parallel.
« Last Edit: January 21, 2018, 01:25:17 am by tigr »
  • Country: ua
« Reply #9 on: January 21, 2018, 03:30:49 pm »
First conclusions.
Incorrect measurement of the capacitance of capacitors. By lowering the readings when measuring in the circuit, creates a false impression of loss of capacitance.
Incorrectly measures the ESR of low-impedance capacitors.
Raising ESR readings several times, creates a false impression of the suitability of the capacitor, hinders the correct evaluation of the ESR of new and used capacitors.
  • Country: ua
« Reply #10 on: January 22, 2018, 05:21:01 pm »
I remember once suggested to the LCR Research,to measure the ESR of a polystyrene capacitor K71-7 0.5uF/250v.A even better 2 in parallel.
HB-14
K71-7 1uF/250v 1%.
ESR-0,000 Ohm.
« Last Edit: January 22, 2018, 05:24:15 pm by tigr »
Offline Shock
« Reply #11 on: January 22, 2018, 06:37:06 pm »
  • Country: ua
« Reply #12 on: January 22, 2018, 07:49:43 pm »
For the sake of interest, I measured with my tweezers 200kHz. I got about 0.003 Ohm.
Offline BravoV
  • +++ ATH1
« Reply #13 on: January 23, 2018, 03:52:56 am »
Yep, very interesting, cause the meter shows current at 49 uA, while you're speaking resistance.  :palm:
I guess you're confused between Ampere and Ohm.
  • Country: ua
« Reply #14 on: January 23, 2018, 03:10:18 pm »
I can very clearly see that you have never made an analog ESR meter.
There the scale near zero is strongly compresed.The first mark  of the  scale  is 0,005Ohm.
This is the payment for the most complex measurements.
Look deeper.
« Last Edit: January 23, 2018, 06:36:34 pm by tigr »
  • Country: ua
« Reply #15 on: February 10, 2018, 12:49:03 pm »
Tables ESR, stored in the memory of Tweezers HB-14.
For standard aluminum capacitors and LOW ESR.
The ESR is measured at a frequency of 100 kHz.
« Last Edit: February 11, 2018, 12:24:18 am by tigr »
  • Country: ua
« Reply #16 on: February 11, 2018, 10:15:15 am »
Let's see how the actual ESR tables works. The standard aluminum capacitors.
Bad capacitor.1000uF 35v.
-5.
Shows how still normal.
Bad capacitor.2700uF 6,3v.LOW ESR.
Abnormally LOW ESR.
-22.
« Last Edit: February 11, 2018, 12:52:40 pm by tigr »
