There's a component inside (called a
PTC) in it that heats up under stress and protects the meter when it gets hot enough.
It has to cool down again for the meter to return to normal and that takes a while.
Is it possible I've damaged the Fluke or somehow compromised its accuracy?
Yes, PTCs wear out, but it's not very likely if you only did it once.
