Author Topic: Problem on Arbexpress  (Read 704 times)
Offline WasabiSCTopic starter
« on: September 05, 2023, 03:00:42 pm »
Good morning/afternoon to everyone,
I'm a newbie to this forum so sorry if the question I'm gonna be asking will be bad, anyway I have this problem:
I am currently using a Tektronics AFG31052 to generate 2 square wave signals (with changing phase and frequency). To do that I have done a small script in Matlab to generate to 'txt' files to plug in Arbexpress and convert them into 'tfwx' format, then by using a usb stick I get the desired signals and thats easy.
What I had in mind was to use the LAN connection to output the signals without going thorugh the USB stick (and maybe not even Arbexpress), I have connected "successfully" my PC to the AFG: I am able to generate simple signals through the Instrument control, but I cant send any file to the AFG nor I can see the Instrument folders. To be more precise when I try to send via File transfer I have the error shown in attachment.
So what Im asking is what Im doing wrong here?
Re: Problem on Arbexpress
« Reply #1 on: September 07, 2023, 09:02:41 am »
SOLVED
To correct this problem just uninstal and reinstall the version of Arbexpress used or perform a downgrade.
