Author Topic: Do affordable current clamp adaptors exists ?  (Read 4807 times)
Offline RoloTopic starter
« on: August 30, 2016, 05:16:37 pm »
Just think with me, I want to do DC-A measurements with a clamp meter, say max 80A - 100A. I prefer to have it as an adapter, so it's connects to my multimeter and I can look at the display in a comfortable way (like in my car seat and turning on the ignition to measure the glow plug current). It does not have to do anything else but current. (DC is a must. AC would be nice) No display, no testleads, just a range selector and a zero button please  :)
Are there any affordable clamp adaptors arround ? About max $100 ? Or do I have to make a bigger hole in my budget ?
Thanks.
Offline AG6QR
    • AG6QR Blog
Re: Do affordable current clamp adaptors exists ?
« Reply #1 on: August 30, 2016, 06:28:49 pm »
I own this one:
https://www.amazon.com/Current-Probe-Clamp-0-60-Amps/dp/B00K0U1N5G
It appears to be rebadged under a few names, including "PDI CA-60".
This model only goes up to 60A.  There's a very similar model, the "PDI CA-600" that goes up to 600A, but with less resolution.
This does work at DC, as well as at not-too-high frequency AC.  In my experience, comparing it to a Fluke multimeter used in-line in Amps mode, over the range where the in-line meter works, it meets its specs for DC amps.  It is not especially high precision.
Offline technogeeky
  • Older New "New Player" Player Playa'
« Reply #2 on: August 30, 2016, 08:04:52 pm »
I own this one:
There is also the PDI CA-400A and PDI CA-400D. I bought the PDI CA-400D it when it was $85, and I might return it. It seems to be more noisy than the PDI CA-60, but I am not yet ready to say that for certain.
I'll be posting a review of them both soon.
« Last Edit: August 30, 2016, 08:07:39 pm by technogeeky »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: August 31, 2016, 05:17:14 pm »
Thanks for the reply's. @technogeeky Would like to see your reviews on these two.
I also did some further searching and found the Benning CC3, it's arround 150 euro here, this is a bit over the budget but for a "made in Germany" meter I might go that far. Not sure if I like the the curled fixed wire. I will look into this brand a bit more first.
And then I found the Fluke 365, is a meter, no adaptor but has a detachable clamp, great idea. With this the clamp gets smaller and the display is readable in a comfortable position. But goes for 300 euro. That's to much for my use of the meter. I do like it  :)
Wil add some pics of these two later.
Offline omgfire
  • Country: ru
« Reply #5 on: August 31, 2016, 05:42:57 pm »
Have you looked at Kyoritsu Kew Mate 2000/2001/2012R, DER EE DE-19A/19B?
http://www.tme.eu/en/details/kt2001/portable-digital-multimeters/kyoritsu/kewmate-2001/
« Reply #6 on: September 03, 2016, 01:16:51 pm »
Thanks for the tip, did not know these models. That DER EE DE-19A look nice, but having an open clamp has drawbacks on the sensitivity (read that on this forum), they will start giving results above 2A.
Been thinking, I think a meter would do if it had a min/max hold function, this would add an extra meter to the bench, and make it more universal.
Offline omgfire
  • Country: ru
« Reply #7 on: September 03, 2016, 02:43:43 pm »
That's the non-contact frequency counter you are talking about? You can measure frequency with leads on de-19a.
« Last Edit: September 03, 2016, 05:57:48 pm by omgfire »
Online Fungus
« Reply #8 on: September 03, 2016, 03:24:00 pm »
Comfort always costs extra.
PS: Could you use a clamp with a simple min-max function? Clamp it, turn key, go back and look.
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #9 on: September 03, 2016, 07:38:58 pm »
you could go and build it yourself, using one of these: http://www.lem.com/
They have clamp style models, and you can get them at many distributors. You only need to add your power supply solution.
We Are The Watt - Resistance Is Futile!
