Author Topic: WB-SG1 wide band generator  (Read 10384 times)
Offline GrandchuckTopic starter
« on: January 23, 2020, 06:19:04 pm »
This unit just arrived so needs more testing.  As a preliminary report, all seems to work as expected.  Amplitude accuracy is nothing to rave about but is acceptable; the frequency accuracy is very good.  The operation range of frequencies is as advertised.
Channel 2 can be modulated by Channel 1, as shown below.
Offline Diabolo
Re: WB-SG1 wide band generator
« Reply #1 on: January 24, 2020, 02:23:11 pm »
Hello,
Ok.
The CH1 frequency of 100 kHz will modulate the CH2 frequency (1080 MHz) by this value (100 kHz) if the "MOD" function of CH2 is ON.
The WB-SGI generator is sold +/- 145 $ / 135 € on Aliexpress, or Ebay.
Serious seller and fast shipping.
- https://fr.aliexpress.com/item/4000468601984.html?spm=a2g0w.12010615.8148356.22.11f0d5c7pfHHq1
The name WB-SG1 would suggest that a version # 2 "WB-SG2" could appear with all the options that are absent on the WB-SG1, but it would be more expensive to buy.
The FA-1 frequency counter was followed by the FA-2 frequency counter.
Diabolo
« Last Edit: January 24, 2020, 04:25:33 pm by Diabolo »
Offline Diabolo
« Reply #2 on: January 26, 2020, 08:42:33 pm »
Hello,
It would be interesting to see the level of harmonics with a spectrum analyzer that I do not have available. If anyone could make these measurements they would be welcome.
What about an FM modulated signal on CH2 ?
For example, a fundamental signal modulated in FM with a deviation of 25 kHz is not likely to resemble an FM signal with a deviation of 100 kHz.
Regards
Diabolo
« Reply #3 on: January 26, 2020, 09:23:38 pm »
Here is the spectrum of channel 2 from 35 MHz to 1.5 GHz.  How does one obtain FM?
Offline Diabolo
« Reply #4 on: January 26, 2020, 09:38:54 pm »
Thank you for the answer.
The manual says that CH2 modulated by frequency CH1 is a CH2 signal modulated in FM.
Diabolo
The following users thanked this post: Kean
« Reply #5 on: January 26, 2020, 10:15:18 pm »
My document states:  CH2 modulation: ON/OFF modulation, modulation frequency 1Hz-1MHz, step 1Hz
Offline Diabolo
« Reply #6 on: January 27, 2020, 05:22:12 am »
ADF4351 produces a 2.2 GHz sinusoidal signal at 4.4 GHz, and produces a square signal from 35 MHz to 2.2 GHz by division of the frequency.
How is the spectral purity of a 750 MHz signal on CH2 which will therefore be a square signal loaded with harmonics?
Diabolo
« Reply #7 on: January 27, 2020, 08:19:52 pm »
The spectrum of an unmodulated 750 MHz signal is shown below.
Does anyone know of any software in the works for this generator?
Offline Diabolo
« Reply #8 on: January 28, 2020, 08:16:33 am »
Hello,
Thank you for the test.
With the WB-SG1 I only got summary documentation without the access codes via USB to obtain certain information or to be able to change some internal data. The FA-2 frequency counter had a few command lines provided to change certain parameters. The web is not very talkative about WB-SG1, alas.
Wait for reviews from other buyers.
Regards
Offline mankan
« Reply #9 on: April 06, 2020, 04:08:26 pm »
There is a WB-SG-OPT15G available now, see https://www.aliexpress.com/item/4000724122338.html. No modulation feature though. I guess it's based on LMX2594. I wonder if there will be a LMX2595 version later?
The following users thanked this post: Grandchuck
Offline Diabolo
« Reply #10 on: April 07, 2020, 12:45:54 am »
Hello,
New frequency generator 1hZ at 15 GHz from BG7TBL called WB-SG1-OPT15G 1hZ at 15 GHz! The output level setting is adjustable compared to the 8 GHz model with the output level fixed.
https://www.ebay.com/itm/WB-SG1-OPT15G-1Hz-15GHz-Signal-Source-Signal-generator-Power-ADJ-OCXO-BG7TBL/233507852253
Characteristics:
overview:1Hz-15GHz wide band output,10M-15GHz with amplifiler adjust,OCXO inside,
support extern connectfrequency stanard
CH1 frequency range:1Hz-200MHz
CH1 step:1Hz-19.999999MHz/1Hz,20MHz-200MHz/10Hz
CH1 output amplifiler:3.3Vpp
CH1 plug type:BNC
CH2 frequency range:10MHz-15GHz
CH2 step:10Hz
CH2 reference output power:+5DBM- -7dBm@1G
CH2 output impedance:50 OHM
CH2 plug type:SMA
inside frequency stadnard:10MHz
inside frequency stadnard type:OCXO
inside frequency stadnard ageing:0.5Hz/year
10M frequency output power:5dBm
extern frequency input range:0dBm to +20dBm
run mode:CH1 frequency mode,CH2 frequency mode,CH1 sweep mode,CH2 sweep mode
front panel:MODE,change mode
ENT:input data
<>^V:left/right/up/down key
CH1:channel 1 output
CH2:channel 2 output
rear panel:10M REF INPUT:extern 10M input
10M REF OUTPU:10M output
USB:USB port
STD ADJ:inside OCXO frequency adjust
power switch
dc plug
power :DC11.7-12.5V,star:less than 0.5A,stabilize:less than 0.25A
weight:350g
accessory: DC12V adapter 1pcs
Regards
Diabolo
« Last Edit: April 10, 2020, 01:24:28 am by Diabolo »
Offline noreply
« Reply #11 on: July 19, 2020, 05:57:24 pm »
Hello,
CH1 plug type:BNC
CH2 step:10Hz
Does anyone have the 15Ghz device?
It would be really nice to verify if indeed there is ability to control the 'output level' in dBm
Looking at the 'specifications'  - as provided on the eBay listing (very limited) - it specifies an output level RANGE (in my humble opinion) and not that it can be 'user defined'  :-\
Remember - output energy is likely to be much higher at lower frequencies - than at 15GHz - so the CH2 reference output power:+5DBM- -7dBm@1G does make sense.
Note - it only specifies -7dBm @ 1GHz
I wonder what it is likely to be at 15GHz?
If it is indeed a decent figure - I am sure that the published specifications would be boasting about it!
The fact that output levels @ 15GHz are not specified - is an indication itself - that there is nothing to shout about  :P
Perhaps someone with an actual device could chime-in  :)
Offline noreply
« Reply #12 on: July 19, 2020, 06:21:20 pm »
Seen a device on eBay already (its not a BG7TBL design) ...
https://www.ebay.com/itm/LMX2595-10MHz-19GHz-RF-Signal-Generator-Frequency-Source-Sweep-OLED-Software-/183730920473
- with these specifications
1, LMX2595 chip features
• 10MHz to 19GHz output frequency
• With 100KHz offset and 15GHz carrier
-110dBc/Hz phase noise
• 45fs RMS jitter at 7.5GHz (100Hz to
100MHz)
• Programmable output power
• PLL main specifications
– Quality factor: –236dBc/Hz
– Nominal 1/f noise: –129dBc/Hz
– highest phase detector frequency
– 400MHz integer mode
– 300MHz fractional mode
– 32-bit score N divider
• Eliminate integer boundary spurs with programmable input multipliers
• Output phase synchronization across multiple devices
• Support for SYSREF with programmable resolution of 9ps resolution
• FMCW's frequency ramp and chirp capability
• Less than 20μs VCO calibration speed
• 3.3V single supply operation
2, LMX2595 chip application
• 5G and millimeter wave wireless infrastructure
• Test and measurement equipment
• Radar
• MIMO
• Phased array antenna and beamforming
• High speed data converter clock (supports JESD204B)
Looks like from their SA plot @19GHz - the output level is -26dBm and there seem to be 'lots' of harmonics in the 'same' region  :-\
Can you really have a reliable 19GHz source without special design considerations and PCB / microstrip factors implemented for a $385 price tag?
Does anyone have this device or made any tests with a LMX2995 design?
Any feedback much appreciated :)
Offline noreply
« Reply #13 on: July 19, 2020, 07:04:46 pm »
Just went down the rabbit hole on the LMX2595 ...
https://www.ti.com/product/LMX2595
That a full development PCB with access to design software (so you can drive this beast) is only $399
Interesting thing is that the LMX2595 device itself is $55 (in 1000 lot)
Looking at the evaluation design - the PCB / connectors / associated electronics / your fabrication and testing time and application software - its not bad value - if you want to build your own stuff - or adapt the EVAL board to your needs.
In the UK - here is link from distributor ...
https://www.mouser.co.uk/ProductDetail/Texas-Instruments/LMX2595EVM?qs=EU6FO9ffTweu4F9rUl5PJQ%3D%3D
Here is the user guide ...
https://www.ti.com/lit/ug/snau219b/snau219b.pdf
At the moment - I simply don't have the time or mindset to go further down this fascinating 'rabbit hole' - however your individual mileage might vary  :-\
Good Luck & Hope above information was useful.
Offline noreply
« Reply #14 on: July 30, 2020, 01:26:18 am »
Looking further into the modulation capability of this device ...
It appears that the frequency set in CH1 will modulate the fundamental frequency set in CH2 - Provided that CH2 out=on and MOD out=on
I had the impression you could modulate the fundamental of CH2 by connecting source to BNC on CH1
I guess this is not how its intended to operate - too bad - it would be a much more flexible device if this was possible and you could use the settings of CH1 as the FM frequency deviation (BW)
Anyone 'opened-up' one of these devices - to see what makes it 'tick'
(I still have not had a chance to do this - just got it today and there is lots of other things which need my attention before I get to the screwdrivers)
- more importantly if there is any way to inject any external modulation?
Great device - I checked the frequency - its clean - harmonics well below fundamental - will do some measurements soon.
Real useful check is to do some phase noise measurements - if no-one has done this already   :-\
Offline mankan
« Reply #15 on: August 12, 2020, 08:17:29 pm »
Stumled across this one eBay auction: #114332851333. Looks like there are 18 and 20GHz options available now.
Output power is now specified further:
1G/8DBM;2G/7.3DBM;3G/8DBM;4G/8.7DBM;5G/9.9DBM;
6G/8.5DBM;7G/4.5DBM;8G/5.2DBM;9G/4.4DBM;10G/3.4DBM
11G/4.3DBM;12G/4.6DBM;13G/3.0DBM;14G/3.0DBM;15G/1.7DBM
16G/-1.4DBM;17G/-4.9DBM;18G/-6.4DBM;19G/-6.5DBM;20G/-8.3DBM
Offline g4dbn
« Reply #16 on: August 27, 2020, 04:17:04 pm »
Has anyone found if there are commands which the WB-SG1 will interpret?  At boot time it shows:
WB-SG1
1Hz-8GHz
SIGNAL GENERATOR
CH1:1Hz-200M CH2:35M-8G
BG7TBL V20191203
but despite trying to fuzz it and lots of keyboard mashing, I couldn't get it to respond at all via the serial/USB.
I can set the frequency via the front panel at up to about 8.7 GHz as you'd expect, but it seems to go a bit flaky at certain frequencies above 8.5 GHz.
This little box could be quite useful with a levelling amplifier and programmable attenuator and filters and a proper decent interface and a proper modulator, but I'm not scrapping my HP E4421B yet.
Neil
Offline noreply
« Reply #17 on: August 27, 2020, 04:49:26 pm »
@g4dbn
Hi Neil,
Welcome to the forum  :)
I have the WB-SG1 and am attaching a user manual for you to look through - if you don't have one already.
I found this device useful - but only for general experimentation.
If you are relying on it to make meaningful measurements - where power levels are important - forget it - its simply not up to the job, despite your idea of leveling amplifier and programmable attenuator.
I looked into this myself and to get an 'accurate' programmable attenuator is a challenge in itself - let alone to 8GHz
- same applies for the leveling amplifier
- now you know why a decent RF signal generator costs big $'s
I also draw you attention to the spectral quality of the signal from the WB-SG1 - its not so pure if you had a closer look with a SA
But despite all of the above - its still a very handy tool for simple testing - where 'empirical measurements' are not important.
« Last Edit: August 28, 2020, 02:28:36 pm by noreply »
The following users thanked this post: g4dbn
Offline texaspyro
« Reply #18 on: August 28, 2020, 06:17:21 am »
I don't see an attachment...
Offline noreply
« Reply #19 on: August 28, 2020, 02:29:36 pm »
So Sorry  |O
It should be there now  :)
Offline g4dbn
« Reply #20 on: September 09, 2020, 05:10:38 pm »
My google-fu was not up to standard, thanks v much for the copy of the manual.  I want to try it for checking the return loss and tuning of some 3.4 and 5.7 GHz feedhorns, using directional couplers, so the absolute level isn't critical.  I'll be using a specan as the detector, so I'm not worried about harmonics and far-out spurs confusing matters.  It'a a whole lot easier than using a set of YTOs.  Might even be enough signal to use the second harmonic to check the SMA-WR90 transitions I'm machining today.
TVM Neil
Offline noreply
« Reply #21 on: September 10, 2020, 10:48:28 pm »
TVM Neil
Sounds good.
The WB-SG1 does produce a signal on frequency, but since it has an external 10MHz input, if you use a 10MHz GPSDO - then you will be 'spot-on' frequency if that's important to you when aligning feedhorns or any associated filters.
Offline Kibabalu
« Reply #22 on: November 02, 2020, 01:15:43 pm »
WB-SG1
1Hz-8GHz
SIGNAL GENERATOR
BG7TBL V20191203
Neil
I also failed to establish any kind of communication with the WB-SG1 via USB/serial. What's the trick?
Offline hpw
« Reply #23 on: March 04, 2021, 06:08:05 pm »
 :horse: how this signal generator performs in terms of PN.... low freq. range and on 10MHz?
Offline videobruce
« Reply #24 on: May 05, 2024, 01:20:08 pm »
Is there a actual manual of the original device in the 1st few posts, NOT the TI device which only has a engineering/builders manual?
