Hi;
Now that I have the Siglent SDS1104X-E oscilloscope, I'm ready to start building projects and experimenting.
Well, almost...
I don't own a signal generator.
I do own a Raspberry Pi 3 b+, and know that I can use it to generate square waves up to about 250Mhz, but what I really want is sine, triangular, and square wave capability.
I have been doing some reading on Arbitrary Waveform Generators (AWG), but not sure I really need anything more than a dual-channel (I want to experiment with signal mixing and harmonics) signal generator.
I originally thought I could use my RigExpert AA-170 antenna analyzer as a signal generator from 100Khz up to 170Mhz, but when I put it on the scope, I realized that it will only generate square waves up to 30Mhz, then it switches to an odd-order sub-harmonic to generate higher frequencies. This was a bit of a mystery as I adjusted the frequency to 30Mhz, then went one step above, and saw the output jump down to 10Mhz. Then I re-read the manual and understood that it was doing what it is supposed to do.
For signals in the audio range, I can use my Pi with the Audio Injector sound card, or my Windows 7 PC with any audio software (I use Reaper) to generate a tone. But I have found that on the PC, the signal is not so stable. It moves about on the scope, and is difficult to trigger properly. Perhaps it would be more stable from the Pi, but I haven't tried that yet.
In any case, I need something capable of generating signals from audio to RF.
I have seen these, ubiquitous ones on Ebay for around $100 for the 60Mhz model, and $50 for the 24Mhz model:
https://www.ebay.com/itm/RD-JDS6600-Series-60MHZ-Digital-Control-Dual-channel-DDS-Signal-Generator-In-USA/232941588491?epid=27005755217&hash=item363c66900b:g:deoAAOSwJb5Zt4WT:rk:42:pf:0These are available in many brands, but are obviously the same inside the case.
I guess one of these would suffice in getting me started, and I certainly don't have a lot of money to spend on this, since I already spent $500 on the scope.
Your suggestions?
Thanks
Ultrarunner
Edit: After I posted this, I began reading some of the user reviews for the Ebay item I linked to. Unfortunately, these units fail miserably at the HF (10-30Mhz) range, and that is where I want to be doing much of my work. So I guess I need to look beyond these apparently falsely advertised products.
Perhaps a vintage HP, Tek, Fluke, Agilent, etc that will take up 1/2 my workbench space, or need to sit on the floor would be a better way to go?
