Any opinion on Appa DMMs? They should be OK, but they are not so popular on this forum. I have never used any.
I scored an unloved APPA 99III Multimeter a while back and I would say it fits somewhere between a Fluke 117 and Fluke 87V in features and performance.
It hasn't got the 87V AC bandwidth but pretty much does everything else, and the compared readings agree. The APPA cable/probes are hard to beat and a lot better than the bog standard Fluke leads.
FWIW to the original poster upstairs: A Fluke 87V, 87-111 and original 87 are a great all rounder meter and won't disappoint. Easy to use and look the business too
Coupled with any reasonable TRMS AC+DC clamp meter with some DMM features on board, you're pretty well covered for many/most scenarios.
Just keep them away from bug zappers and barbeque starters
or string together nine x 10meg resistors in series with the positive lead as I do for those special HV low current DC occasions
It might set you back a dollar or two, still cheaper that taking out a pricey multimeter.
