Author Topic: Choosing between entry-level 12-bit DSOs  (Read 353265 times)
Online nctnico
Re: Choosing between entry-level 12-bit DSOs
« Reply #225 on: April 07, 2024, 09:34:05 pm »
* Also, H,A,D,T feel meaningless. Takes longer to interpret them as Horizontal, Acquisition, etc., than if they were totally omitted and people could see the meaning from the units alone (e.g. ns/div etc) or smaller full text like the MXO 4, but appreciate that might not be possible on the smaller screen Rigol.
Squeezing the important information onto a limited display isn't a new issue. It was addressed successfully in the '80s by many pieces of equipment from many manufacturers. Start with scopes, spectrum analysers, logic analysers, ... from LeCroy, TK, HP....The
Why can't today's weenies do better?
IMHO you are severely suffering from over-glorifying the past here  ;) . Having a 640x480 screen is not enough for having lots of information on your screen. Back in the old days, I'd print output from a logic analyser so I could at least have a readable overview of the signals. And using the first generation mixed signal Megazoom scopes from HP wasn't very joyful either without colors (except green) while having 16 digital + 2 analog traces on screen. The bottom line is that modern day equipment can do much more and thus need to display much more information.
« Last Edit: April 07, 2024, 09:39:03 pm by nctnico »
Offline shapirus
  • Country: ua
« Reply #226 on: April 07, 2024, 09:38:07 pm »
The Rigol display should be able to do far better, I'm speculating, but it's possible they are using GUI frameworks intended for much higher-res larger displays, and that's causing the very awkward look/feel.
They could simply open source their API/ABI and allow people to create their own GUI, or, even better, open source the entire GUI app and let the community modify it.
It would only boost their sales.
But no.
Offline tggzzz
« Reply #227 on: April 07, 2024, 09:53:49 pm »
Unfortunately, marketing has overtaken engineering principles in just about every industry. I bought a kitchen appliance recently that has about 30 presets that are totally useless and just make the device harder to use. Give me two adjustments, temperature and time, to set. But then you couldn't print "30 Presets" on the box to outdo the other brand that only has 25 presets. ::)
No doubt all the presets are hieroglyphs.
I've had similar problems with microwave ovens. I baffle the salesdroids when I ask them how to set it for 22s at 30% power. I refuse to consider buying one where I can't do that basic operation.
You are probably expected to control it from a smartphone app, at least while their servers are still operational.
Offline tggzzz
« Reply #228 on: April 07, 2024, 09:55:29 pm »
But no.
Digilent Analog Discovery has such an API, or you can write JavaScript to control it.
Offline tggzzz
« Reply #229 on: April 07, 2024, 10:00:13 pm »
Agree. For instance, HP spectrum analyzers packed all manner of useful information within a low-res monochrome printout.
Exactly what I was thinking of.
Possibly.
Never underestimate the idiocy of an graphic designer or MBA having control over a product.
« Last Edit: April 07, 2024, 10:35:28 pm by tggzzz »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #230 on: April 07, 2024, 10:09:07 pm »
could you ask the same to siglent? maybe only in your wish, rigol has had success without open sourcing... open sourcing it will create another ubuntu red hat gnome and plethora countless number of linux like variant by kids who oh i like this, and then  another oh i like that. it will be dizzying to choose. i'd rather one GUI to learn and familiarized with rather than distracted by other aesthetically correct GUI. personally i dont get distracted by toyish GUI of rigol, i know where to look what i want to look, and icons can help recognizing things in case we forget. if they maximize graph display, text will be small and unreadable and it will generate complaints too. well i dont want to get deep into aesthetically correct discussion, its subjective. for anyone with ADD, get black and white screen, done..
Offline 2N3055
  • Country: hr
« Reply #231 on: April 07, 2024, 10:26:21 pm »
So topic: "Choosing between entry-level 12-bit DSOs"
what is being discussed:
- that modern shit is useless : buy old crap CRT scope
- that modern shit is useless : buy old crap CRT sampling scope
- all stuff should be Open source. Including toilets. Enough of that tirrany!!
- it is irrelevant which scope you buy. Real man make their own software and scope.
- 20000 USD scopes with 16" screens are better than 400 USD scopes with 7" screens.
- modern shit is crap.
- all advanced features should be ignored and you should not use it. Because they require learning.
- since you are forbidden to use any advanced features or measurements then it doesn't matter which scope is more capable.
- really, just get FINRSI. More than that is just a conspiracy theory to get your money.
- scope color is 80% of choice.
 :-DD :-DD :-DD :-DD
The following users thanked this post: Performa01, egonotto, newbrain, KungFuJosh, EvgenyG
Online tszaboo
« Reply #232 on: April 07, 2024, 10:29:46 pm »
Oh I did that. 16 digital channels with the horizontal and vertical 10 tics turned the scope into a checkerboard. Completely unusable. You could fit maybe an SPI and 2 other signals on the screen, otherwise I think it was clear you were supposed to turn off everything and maybe look at the decoded signal of an 8 bit parallel bus max.
Online nctnico
« Reply #233 on: April 07, 2024, 10:34:04 pm »
GW Instek just released a scope (MPO-2000) where you can program your own signal processing functionality + GUI using Python and LVGL. The programming interface allows full control over remote test equipment over ethernet and/or USB as well.
« Last Edit: April 07, 2024, 10:35:53 pm by nctnico »
The following users thanked this post: shabaz
Offline BillyO
« Reply #234 on: April 07, 2024, 10:34:43 pm »
 :-DD :-DD :-DD :-DD
LOL!  Great summation!
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Online KungFuJosh
  • TEAS is real.
« Reply #235 on: April 07, 2024, 10:49:45 pm »
shit is crap.
Truer words have never been spoken. 😉
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline vk6zgo
« Reply #236 on: April 07, 2024, 10:58:33 pm »
It doesn't need to display every bit of information at the same time.
Offline tautech
« Reply #237 on: April 07, 2024, 11:00:03 pm »
Nonetheless, there is far too much distracting rubbish on that scope display.
:=\ Yawn
Agreed, it can be difficult to teach old dogs new tricks.  :P  :horse:
So let's examine what we do need:
Trigger channel and type, coupling, position and level
Active channel/s, BW limited ON or OFF, probe/input attenuation, channel 0V level and input impedance
Timebase, s/div, Mem depth and sampling rate
LAN and USB connectivity indication.
Time/date
What's superfluous or missing ?
« Last Edit: April 07, 2024, 11:44:21 pm by tautech »
Out of office and unavailable for a few days.
Offline tggzzz
« Reply #238 on: April 07, 2024, 11:10:14 pm »
:=\ Yawn
Trigger channel and type, position and level
Time/date
:=\ Yawn
Agreed, it can be difficult to teach nappy wearers to read and comprehend what was written, and not to construct strawman arguments. And to have to repeatedly remind readers to remember to "follow the money".
That doesn't look like that crap Rigol GUI. How have you got rid of the crap and left more room for the useful information?
« Last Edit: April 07, 2024, 11:12:08 pm by tggzzz »
Offline BillyO
« Reply #239 on: April 07, 2024, 11:12:49 pm »
:=\ Yawn.
By buying a good scope.
Offline Harrow
« Reply #240 on: April 07, 2024, 11:12:56 pm »
Only because you asked....a true minimalist might not have that menu permanently across the top of the screen. Instead, a small icon in the corner could bring it up in a jiffy when needed.
Offline tautech
« Reply #241 on: April 07, 2024, 11:17:04 pm »
Zip/nothing/nada !
Default display where everything is user configurable.
This is set almost exactly how we dispatch them.
That's just how I like to have my scopes set when I power them up.
If I want/need further crap I can choose to activate it or not.
All/any menu can be set to autohide 3s-1m or stay visible. Pop down menus can be set to compress or overlay the display. I prefer compress as it doesn't hide any of the trace.
You can see the Ch4 menu tab top right (last menu used) which can be recalled with touch/clicking the tab or pressing the channel button or menu hidden touch/click on it or any vacant portion of the display.
Just ask if you need to see any of this functionality.
« Last Edit: April 07, 2024, 11:47:54 pm by tautech »
Offline shabaz
« Reply #242 on: April 07, 2024, 11:27:09 pm »
I got curious how previous-gen (i.e. smaller screen) 'scopes do it, and never noticed before, but the older Tek scopes would push into the trace display area once additional stuff like measurements etc were added. In use to me it felt unobtrusive, there was a button to remove that if the full screen view without the clutter was needed, and then press the button again to bring everything back.
Not saying it's good or bad, just a data point on one way they solved things at that time on the low-res screens.
« Last Edit: April 07, 2024, 11:33:55 pm by shabaz »
Online DaneLaw
« Reply #243 on: April 07, 2024, 11:29:54 pm »
Some context
Offline Harrow
« Reply #244 on: April 07, 2024, 11:33:10 pm »
 :-DD :-DD :-DD :-DD
Would it be too conceitful for me to think that as a newcomer, I've managed to contribute to 20% of that list? I feel honoured indeed! ;D
« Last Edit: April 08, 2024, 12:00:30 am by Harrow »
Offline shabaz
« Reply #245 on: April 08, 2024, 12:14:32 am »
(Some screenshots from the video pasted below, to save having to watch it all, although it's interesting).
From the video, the MPO display looks neat, with little wasted space on text that's not needed. It is obvious what the units like pts, MSa/s etc refer to.
The supplied apps displays look as clean as imaginable, with decent axis titles with units. I can't see how those could be improved further.
The Python GUI functionality looks like it can be integrated into the normal instrument controls.
When I first heard of the Rigol, I found the idea that they'd used Android intriguing, and probably a lot can be done with it, but in terms of practicality, I'd much prefer Python integrated into the instrument. (With Rigol, I guess what could be done, is Python as a separate app installed in the instrument, communicating via SCPI? but it's not the same at all, but perhaps a compromise).
I know the MPO-2000 is not 12-bit, but 12-bit takes a super-decent FFT (by that I mean super-usable, fast responding with decoupled controls like start/stop-freq/RBW, unlike the older scopes had) to extract max use of it (since there's only so much to see on a time-domain trace view, even zoomed in), and the MPO actually does have really good spectral analysis (if they have taken their MDO-2xxxEX functionality and reused it). It's a different price-performance of course, since costs are completely different too. But I think it's still reasonable to compare some aspects such as the display/UI.
The Rigol and Siglent, although I know so little about these instruments, are for sure tremendous price-performance (who could have imagined 12-bit scopes at that price!), but that MPO is also highly tempting with the all-round features (including dual AWG and PSU) and (expectedly good) SA and Python capability, everyone is different.
« Last Edit: April 08, 2024, 12:29:20 am by shabaz »
Online KungFuJosh
  • TEAS is real.
« Reply #246 on: April 08, 2024, 12:22:38 am »
This thread is primarily discussing entry-level scopes under $1000 (really under $500). Why are y'all discussing that $2000+ programmable scope?
The following users thanked this post: CastleCustodain
  • Country: my
« Reply #247 on: April 08, 2024, 01:32:10 am »
Some context ...
i thought to totally change dso's screen GUI. if to add functionalities like that, thats what i wish to have in my Lecroy SDA scope, and better if its available in these cheap entry scopes discussed in this thread. but python is for new kids, we program in c/c++ well... better something than nothing... but as mentioned it $2K scope. one reason why i became rigol addict, because its the cheapest scope yet decent builtin spec, and more importantly PC Windows API provided, to some extend we can control the scope from PC, but i'm not interested at that, what matters is i can download data to PC, with data in PC, i can do whatever processing i want, similar feature/function/processing as 2K or 10K scope if i want to. i know siglent also provides such API nowadays but they came much later. ymmv.
Offline Fungus
« Reply #248 on: April 08, 2024, 01:39:23 am »
Meh.
It's fun to imagine but you won't even notice the difference in screen height when you're using it.
Horizontal is what counts and they're both the same.
Offline vk6zgo
« Reply #249 on: April 08, 2024, 02:05:18 am »
:=\ Yawn
Time/date
It is much less cluttered than the Rigol, & just says "SIGLENT" once, in a small font, unlike Rigol who have to shout "RIGOL" at us & in addition have a large "R" badge.
I'll know if I'm using a Rigol, so why do they have to keep reminding me?
I could use such a device as the Siglent without becoming infuriated more than once or twice a day, & that is pretty good for an "Old man who yells at test equipment"!
Of course, Rigol aren't the only or even the worst offenders, Hantek  :-X are repeat offenders!
