Set expectations accordingly and hopefully you'll be fine. After sds2074 I thought the Rigol Ds4014 was the way to go. But I found the 140M memory unuseable in zoom (I'd make an adjustment and machine would take minutes to cycle through queue of zoom adjustments), I found i2C decode only worked on 100ms/div or faster even though sample rate was very fast (so why have 140M memory) and i2c decode did not work with segmented memory. That and unit locked up twice in 2 hrs. I had an issue with cursors in roll mode, no zoom in roll mode. Maybe my unit was bad, but it drove me crazy for a $2500 USD instrument. So to me, the 140M, segmented memory and i2c decode did not meet expectations. I use pretty high end scopes daily so I have fairly high expectations..i'm probably not their target market. Coming out of school years ago I'd take either of these scopes in a heartbeat and just grind through the issues.
