Author Topic: Chinese voltage reference module  (Read 7136 times)
Offline bigskyTopic starter
« on: October 23, 2014, 02:41:33 pm »
I just got one of the chinese voltage references on ebay. It cost GBP 13 and took under three weeks to arrive.
Here are some pics of it with my 87V, which dates from just after the GSM RFI fix  so about three years old.
I don't know what more there is to say, especially given the accuracy of the meter in hi-res mode.
Offline Fungus
Re: Chinese voltage reference module
« Reply #1 on: October 23, 2014, 03:10:03 pm »
Which voltage reference? This one...?
http://www.ebay.com/itm/181112567159
The chip it's based on: http://www.analog.com/static/imported-files/data_sheets/AD584.pdf
Where to get one: http://www.ebay.com/itm/360853364819
« Reply #2 on: October 23, 2014, 03:23:52 pm »
Yes, that one. I thought people would know it's built around the AD584. My 87V hasn't been calibrated or adjusted since it left the factory.
Offline Fungus
« Reply #3 on: October 23, 2014, 03:25:54 pm »
It's an interesting topic...
How do you guys test your meters (if at all)?
I made a little tester a couple of weeks ago that does ohms, volts and amps. It has:
10 kOhm and 1 kOhm - 0.01%
5V and 2.048V - 0.05%
10 mA and 100 uA - 0.5%
Here's a quick snapshot with my crappy 'phone. Note 8-pin SOIC adapter boards   :P
(I need some taller standoffs so I can put another board underneath to hold the 9V battery and make it pretty...)
« Last Edit: October 23, 2014, 05:06:55 pm by Fungus »
Offline Fungus
« Reply #4 on: October 23, 2014, 03:36:15 pm »
I don't think they drift much, if at all. They're designed not to.
The only people who need regular calibration are people who have to cover their asses when lawyers appear.
« Reply #5 on: October 23, 2014, 03:37:03 pm »
(I need some taller standoffs so I can put the 9V battery underneath and finish it off...)
If you're not careful it will end up looking like:
See http://www.voltagestandard.com/DMMCheck.html
And on here https://www.eevblog.com/forum/chat/incoming-stuff-voltage-reference/
Offline Fungus
« Reply #6 on: October 23, 2014, 03:42:18 pm »
Cheap-ass gadget. My little metal hoops are gold plated!   ::)
And instead of getting some decent resistors they just got some 1% resistors, measured them, then wrote the readings on a piece of paper. Tsk.
« Last Edit: October 23, 2014, 05:06:20 pm by Fungus »
Offline Fungus
« Reply #7 on: October 23, 2014, 06:41:49 pm »
This unit was already discussed earlier - however connect once the output with a sensitive scope using AC coupling ... - the output is very noisy ...
I haven't actually looked at mine on a 'scope but that's why I put those two capacitors right behind the voltage references. I figured that between the battery power source and those capacitors there wasn't much else I could do.
(Plus: My old Fluke measured exactly 5.00V and 2.048V on the very first attempt so I decided I was good to go...)
Offline metasequoia
« Reply #8 on: October 25, 2014, 02:53:29 pm »
I would like to make a correction to the statement regarding the 100K, 10K, and 1K resistors used on the DMMCheck made by voltagestandard.com- they are 0.1%, 25ppm/C parts.  If you look closely at the photograph you can see that the color of the tolerance band is violet, indicating 0.1% tolerance.
