Author Topic: chinese oscilloscope jds2012a teardown  (Read 13203 times)
Offline jimanisTopic starter
« on: July 09, 2015, 07:26:37 pm »
hello and sorry for my English...this is inside  of this Chinese oscilloscope ... on the ic they  have delete the codes..  :--
« Last Edit: July 09, 2015, 07:29:33 pm by jimanis »
Offline Lightages
  • Canadian po
Re: chinese oscilloscope jds2012a teardown
« Reply #1 on: July 09, 2015, 08:30:55 pm »
Thanks. But you forgot an image of the assembled unit so we know what it looks like. ;)
Offline frenky
  • Country: si
    • Frenki.net
« Reply #2 on: July 09, 2015, 08:40:46 pm »
Quick search finds this:
Offline ataradov
    • Personal site
« Reply #3 on: July 09, 2015, 09:07:55 pm »
Well, who does not want a "fully functiognl" scope for "the use of safe"  :-DD
Alex
The following users thanked this post: ogden, BobRyan
Offline Deathwish
  • Country: wales
« Reply #4 on: July 09, 2015, 09:23:21 pm »
Meh, try Dave our host for getting into his one.
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline JoeB83
  • Longmont, CO
« Reply #5 on: July 10, 2015, 04:12:52 am »
Fully function + gl. ;)
Id also like to know what "multi-usaage" is.
« Last Edit: July 10, 2015, 07:22:34 am by JoeB83 »
Offline JoeB83
  • Longmont, CO
« Reply #6 on: July 10, 2015, 05:39:44 am »
Plus it looks like it charges from the same charger my Canon SL1 DSLR charges from.....
Offline Rasz
    • My random blog.
« Reply #7 on: July 03, 2017, 03:13:18 pm »
Good news everyone! Jinhan also makes dual channel version of this glorious beast, JDS2022A.
Teardown:
25MHz sine:
$140 free shipping.
2x AD9288 + some FPGA/CPLD, based on the scratch marks either Lattice cpld or Altera Cyclone 2? + some ARM micro + 320x240 LCD. Not bad for the price, might be useful after hacking as a cheap PC analog input.
Offline LogicalDave
« Reply #8 on: September 03, 2017, 12:34:31 pm »
I purchased the JDS2023 that has two channels and includes a 5MHz signal generator.
I tested it quickly using a lab-grade RF signal generator and confirmed the 20MHz bandwidth specification; it clearly shows at least 10 points per cycle of the sinewave (validating the 200MS/s specification) and there is no amplitude compression of the 0dBm signal (nominally 0.632vpp into a 50-ohm load – this is unloaded so it correctly shows 2x vpp); the analog front end 3dB compression point is somewhere north of 40MHz.
Offline 001
  • Country: aq
« Reply #9 on: November 11, 2017, 09:02:46 am »
It can make "screenshots" only? PC integration only as flashdrive with screenshoots, isnt it?
Offline Rasz
    • My random blog.
The following users thanked this post: 001
Offline cliffyk
    • PaladinMicro
« Reply #11 on: May 30, 2019, 12:23:13 am »
Hello all,
I realise this is an OLD thread, however I just purchased on of these 'scopes (from Amazon, $150.00) to sort of replace my old OWON HDS1022M-N which died an untimely death when its plastic outer case decided to disintegrate in my hands (it's listed on eBay for parts,the battery, display and boards are all intact and OK).
The OWON was nearly $600 when i  bought it in June of 2009--this guy is close to its equal, at 1/4 the cost--though i do miss the FFT and waveform averaging functions the QWON offered. The unit I received (claimed to be "new") was apparently produced in July of 2017, anf differs from all that I have seen in it's control button labeling--mine has hybrid Chinese/English legends on the function buttons. THe supplied documentation sucks, apparently machine translated from Chinese; but with some fiddling and a basic knowledge of handheld DSOs it's not the difficult to figure out.
I also found that the dual battery box had intact terminals for the "spare" cell (unlike some i had seen on YouTube and elsewhere); so I jumped it to be in parallel with the live cell. As the instrument does not attempt to charge the cells I saw no downside to this, and now enjoy 8-10 hours of use from a set of cells...
envision their being jumpered:
My one significant impression is that this is a real test instrument, designed to be such; not some flahey 200 kHz hobbyist level, overworked micro-controller/FPGA based toy like so many others in its price range...
-cliff knight-
paladinmicro.com
Offline ebclr
« Reply #12 on: May 30, 2019, 01:17:53 pm »
"Well, who does not want a "fully functiognl" scope for "the use of safe"  :-DD"
Try to write this in Chinese, and let see if you do any better.
Don't be xenophobic  :box:
Offline tkamiya
« Reply #13 on: May 30, 2019, 03:20:17 pm »
The green solder mask look awful, especially near CPU.
Are the gray stuff heat sink compound or so that no one can copy their design???
The following users thanked this post: cliffyk
Offline sdouble
« Reply #14 on: May 30, 2019, 07:11:42 pm »
I'm not a native english speaker.
but this is clearly a blog where people communicate in english. I did find that people here are rather understanding with any sort of mistake. However, every contributor should do its best to produce understandable sentences. Asking people to make an effort has noting to do with xenophobia.
Offline ogden
  • Country: lv
« Reply #15 on: May 30, 2019, 07:19:59 pm »
Hire someone who knows target language well.
Don't be ignorant  |O
Offline cliffyk
    • PaladinMicro
« Reply #16 on: May 30, 2019, 07:52:24 pm »
The effect seen is an artifact of the crappy combination of incandescent and electronic flash lighting I used when photographing the unit's insides--it is actually quite well made for it's price point. And of course they attempt to protect their design 'twould be silly not to...
-cliff knight-
paladinmicro.com
Offline coromonadalix
« Reply #17 on: May 30, 2019, 08:38:08 pm »
Im always annoyed to see they dont care about flux residues left  :-- :wtf:
Offline Rasz
    • My random blog.
« Reply #18 on: May 30, 2019, 08:43:48 pm »
its called NO CLEAN for a reason
