My 2 DL24M load testers arrived over the weekend. This isn't what I was expecting. It's been a while now since i ordered, but I remember something else than what they show now. Maybe I'm remembering it wrong, but I don't remember this modular design.
https://www.aliexpress.com/item/1005002621436227.html?spm=a2g0s.9042311.0.0.5bf44c4dEGxk3vI opened the box to find many smaller boxes inside. At first this was confusing as I distinctly remember the DL24M differently from what I received.
This is the control module which is supposedly good for 150 watts. If that is the case, each added mosfet ought to add 150 watts. I'm somewhat skeptical...this is a Chinese product after all! No USB port and I'm guessing the BT module is inside the LCD shell. You use the 5 holes on each side for adding another mosfet for more wattage. A mosfet module on each side, plus the one on the control board ought to be 600 watts. It appears you can daisy chain them together a lot more than just 3 mosfet modules.
Far from enough screws and nuts, same janky PSU, same hardware set as the DL24P.
This is a mosfet module. There is no gate protection or a diode on board. All that is here is a mosfet and heat sink on a board. The 5 through holes on each side are identical and allow you to connect the mosfet modules in parallel with other modules or with the base unit. Since I have 6 mosfet modules, I have to wonder if I can connect them all to a single control module.
Too bad there is still a single TO-220 Schottky diode. This thing got hot on the DL24P. I bet at much more wattage it will be nuclear!
The rest of the main board logic looks similar to the older ones. I don't see any zeners here, but then I have no idea what all the smaller components are yet. Lots more shunts is good! I guess the board by itself is unjumpered. Adding mosfet modules and jumpering 200w, 450w or 600w is for 1, 2 or 3 mosfet modules. A set of instructions WITH the load tester would be nice and there is almost nothing. I wonder what those 2 8 pin chips are that have their tops scrubbed off?
