Author Topic: New Jyetech M162 LCR meter (april 2022)  (Read 4550 times)
Offline tunkTopic starter
  • Country: no
« on: April 24, 2022, 06:10:38 pm »
Looks like Jyetech recently has released a new LCR meter: https://jyetech.com/m162-lcr-meter/
Full schematics in the link, uses a STM32F303CC. Banggood sells it for 50us$ (plus a 6us$ case).
Specs:
- R, |Z|: 0.1Ω - 20MΩ
- C: 1pF - 20000μF
- L: 1μH - 20000H
- Q, D: 0 - 10000
- Θ: -90° - 90°
- Accuracy: About 1% (tested for resistance 1Ω - 1MΩ)
« Last Edit: April 24, 2022, 06:53:50 pm by tunk »
The following users thanked this post: thm_w, edavid, morgan_flint
Offline LeonR
  • Country: br
  • PC hardware enthusiast
Re: New Jyetech M162 LCR meter (april 2022)
« Reply #1 on: December 05, 2023, 10:15:58 pm »
 I was browsing AliE for newstuff and just found out about that little LCR meter. Has anyone here got their hands on a copy and would mind sharing his thoughts? Seems like the "ultimate" low-cost LCR solution for the hobbyist.
Offline Gyro
« Reply #2 on: December 05, 2023, 10:56:27 pm »
It's the first time I've seen this. One thing that stands out from the spec is the maximum measurement frequency of 1kHz (100Hz and 1kHz available). On the face of it, this could be a limitation for a lot of high frequency parts. The DE-5000 (around twice the price but fully cased) goes to 100kHz.
Best Regards, Chris
Offline S57UUU
  • Country: si
« Reply #3 on: March 14, 2024, 06:27:37 am »
I work mostly with RF, and very often use inductors smaller than 1uH. When I saw this video:
where he measures short pieces of wire of 20 and 40nH (towards the end of the video), I was hooked, and immediately ordered one.
But when I got it,  it won't measure such low inductances..
On the video, there is a prominent caption stating "Measurement frequency: 10kHz", however mine offers only 100Hz and 1kHz.
Could this be just the wrong version of firmware? Or has the hardware changed? The PN on the board is slightly different than that on the video and the picture on Aliexpress?
Offline S57UUU
  • Country: si
« Reply #4 on: March 14, 2024, 12:36:38 pm »
I asked in the youtube comments, and jye replied that the board is the same, just some components have changed. They promised to publish the needed modification of HW and FW.
  • Country: no
« Reply #5 on: May 12, 2024, 01:11:49 pm »
Looks like they introduced a 10kHz version: https://jyetech.com/m162-10-lcr-meter/
Instructions on how to convert the old version to 10kHz:
https://jyetech.com/wp-content/uploads/DN162-06v01_HowToConvertM162toM162-10.pdf
Offline kn4jrf
« Reply #6 on: August 13, 2024, 04:06:34 pm »
I just got one.  Pretty slick, but max R on mine won't go higher than 1M ohms (actually 1.74M), not the 20M claimed in the specs.  I tried measuring a 10M resistor with a DMM and it reads fine.  But the M162 won't even read at all.  I sent JYE Tech a message for help the other day, but so far, no response.
