Author Topic: Cheapo LCR-T4 ESR Meter Transistor Tester  (Read 12139 times)
Offline StillTryingTopic starter
  • Country: Broken Britain
« on: October 06, 2016, 12:33:01 am »
http://www.ebay.co.uk/itm/LCR-T4-ESR-Meter-Transistor-Tester-Diode-Triode-Capacitance-SCR-Inductance-/322192982166
Are there any menus or calibration on this version, I've tried shorting 1-2-3, holding the button for ages, and both together, it just shows a 0.04 and 0.05 resistor then turns off!
Offline vinceroger
Re: Cheapo LCR-T4 ESR Meter Transistor Tester
« Reply #1 on: October 06, 2016, 06:27:01 am »
This video also shows to short pins 1/2/3 then it starts to calabrate i wonder if your meter is faulty somehow? can you return it
« Last Edit: October 06, 2016, 06:29:09 am by vinceroger »
« Reply #2 on: October 06, 2016, 01:02:28 pm »
I could return it but as it seems to work and I only paid about a £5'er for it, it hardly seems worth the trouble.
It reads resistance and capacitance about 1.5% high, over 1M it reads 2% high, and it reads it's Vbat about 0.22V low.
This post is exactly the same board and screens, - never shows any name or version number, or any bleedin' menu/calib no matter what.
https://www.eevblog.com/forum/testgear/lcr-t4-mtester-v2-07-lcr-meter-black-block-issue/msg1001355/#msg1001355
I might try to re-flash it one day.
Offline vinceroger
« Reply #3 on: October 06, 2016, 02:02:26 pm »
you paid for a working meter though so i would contact the ebay seller as they may have a bad batch they may send you a fully working one in the post but yes a firmware upgrade would probably sort it out.
Offline Gyro
« Reply #4 on: October 06, 2016, 07:44:54 pm »
Regardless of being able to get into the calibration menu, the tolerances you list, together with the shorted pins readings sound pretty good for this tester.
Try searching the Main $20 LCR ESR Transistor checker project thread...
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
Best Regards, Chris
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #5 on: October 06, 2016, 08:36:38 pm »
Yep, madires in that thread is the developer for the software and the hardware design that all of those testers are using. That thread is pretty much the english language facing developer thread.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
« Reply #6 on: October 06, 2016, 08:50:04 pm »
I agree, it's often reading 0.01R,0.01R or even 0.00R,0.00R ATM, so can't argue with that. Still intrigued that it won't go into any sort of menu though.
Yes, I keep having a read of the other long thread.
« Last Edit: October 06, 2016, 08:52:40 pm by StillTrying »
Offline TheBay
  • Country: wales
« Reply #7 on: October 06, 2016, 09:38:40 pm »
This firmware doesn't have a "Menu"
