Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
SDG 1032X - How to turn on both channels at the same time?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: SDG 1032X - How to turn on both channels at the same time? (Read 799 times)
mio83
Regular Contributor
Country:
on:
July 09, 2021, 07:39:23 pm »
Hello,
I own a the AWG SDS-1021X from Siglent.
I found myself in the situation of needing to turn on both channel at the exact same time.
However, searching in the interface and then looking in the manual, I failed to find this option.
I am pretty sure it must be a supported option, so I am probably overlooking something simple.
Do you know what should be done?
Thanks!
MANUAL:
https://www.batronix.com/files/Siglent/Funktionsgeneratoren/SDG1000X/SDG1000X_Manual_EN.pdf
Logged
ledtester
Super Contributor
Country:
Re: SDG 1032X - How to turn on both channels at the same time?
Reply #1 on:
July 09, 2021, 07:56:49 pm »
Would activating the channels via SCPI work for you? According to the programming guide you would have to send two commands from your computer - one for each channel - but they should execute within milliseconds of each other.
The SDG Programming Guide may be found on this page:
https://www.siglent.eu/product/1136898/siglent-sdg1032x-30mhz-function-arbitrary-waveform-generator
Logged
mio83
Grandchuck
Frequent Contributor
Country:
Reply #2 on:
July 09, 2021, 08:06:19 pm »
Can you use a double pole switch or relay?
Logged
mio83
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
