Author Topic: Siglent SDM3055 bench meter relay question  (Read 726 times)
Offline DanielSpokaneTopic starter
« on: June 16, 2019, 06:57:27 am »
Hello,
I have a Siglent SDM3055. Overall I'm very impressed with the meter. However, for the first time I was playing with the dual display mode. The dual display seems to work fine, however when I run dual AC and DC readings I hear the meter relay "clicking" about every second or so. Is that normal?
Offline tautech
Re: Siglent SDM3055 bench meter relay question
« Reply #1 on: June 16, 2019, 07:10:46 am »
Hello,
Yep, quite normal.
The relay switches the low level signals after the dividers/shunts etc so contact life isn’t an issue.
The following users thanked this post: DanielSpokane
