Author Topic: Variable switching power supply  (Read 38533 times)
Offline David Hess
  • DavidH
Re: Variable switching power supply
« Reply #50 on: July 27, 2017, 09:43:31 am »
Why do they insist on putting ground in the middle? And use yellow instead of green?  :palm:
Is that center terminal ground or common?  I assume it is ground since that is what it says so the output is floating but that just means a standard 3/4" banana plug cannot be used so I agree, the design is poor.
And since they did not use the binding post style of banana jack, you cannot easily bridge ground to one side.  Or maybe the output actually is not floating but then they did not bother indicating that?
I do not need to evaluate anything more to know that the designers did not know what they were doing.  This thing is trash.
The best terminal arrangement I have used places the binding posts for negative, positive, and ground in a 3/4" equilateral triangle.  For a tracking supply, this requires 5 posts in a W configuration with two ground posts or two common posts.
Don't have a clue why they need (think they need?) all those lytics, but design looks pretty solid and safe.  Look at those slots!
The first thing I thought upon seeing all of those small aluminum electrolytic capacitors is, "There is a wearout mechanism and reliability problem waiting to happen."
Offline RetroDan™
« Reply #51 on: July 27, 2017, 02:21:01 pm »
Did you connect a load?
Come on, he can't possibly be that thick...
... can he?
*rolls eyes* Yes, I connected a load.  I didn't think that I needed to explain things down to that level.  I also inhaled and exhaled in order to keep from passing out, but I didn't feel the need to have to explain that, either.
I'll just buy the parts to build my own - I was just trying to do things the easy way, and got the short straw.
Oh, by the way?  Super thrilled at your commentary, Dave - always nice to have someone assume I'm a complete ignoramus.
« Last Edit: July 27, 2017, 02:30:35 pm by RetroDan™ »
(**A new 3rd Edition** companion is in preparation, expected publication 4Q15: “Learning the Art of Electronics — A Hands-on Approach”)
Offline Rerouter
« Reply #52 on: July 27, 2017, 02:28:53 pm »
dan, try lifting the lid and make sure there is nothing loose, there is a plug for the current set pot, equally does it sit on the CV light or CC, if you have a load and it remains at CV, then your from terminals may not be making contact,
The voltage is measured pretty close to the output, and the current over a shunt near to the output,
Offline RetroDan™
« Reply #53 on: July 27, 2017, 02:32:32 pm »
Already checked the connections for continuity.  I'm not sure where the problem is, but it's a moot point now.  I've already sent it back; as mentioned in my previous post, I'll just build my own.
Offline nctnico
« Reply #54 on: July 28, 2017, 10:22:17 am »
... can he?
Ofcourse you have to explain that. Or do you have a working crystal bowl? You'd be the only one! There are lots of elementary things that can go wrong. For example: did you measure the voltage across the load with a multimeter? Perhaps you did but it is impossible to judge your fault finding skills from behind a screen so you have to tell us what you did to diagnose the problem yourself in great detail to get answers which are usefull to you.
« Last Edit: July 28, 2017, 10:25:22 am by nctnico »
Offline RetroDan™
« Reply #55 on: July 28, 2017, 01:12:43 pm »
Fair enough; from now on, I'll err on the side of loquacity.  Still think Dave's response was unneccesary.
« Last Edit: July 28, 2017, 02:14:33 pm by RetroDan™ »
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #56 on: August 10, 2017, 12:07:12 pm »
There is a fair number of complete beginners rolling through the forums and for many some things as trivial as these might not be trivial to them. So the default assumption when a newbie calls a piece of test equipment shit is to assume that they are not using it correctly. We can't possibly know your level of experience to rule out the trivial stuff by default.
That being said, I apologize for being condescending and hope you managed to sort the problems out with the power supply.
Side note: I'm aware that 2 weeks have passed since the last message, I only now stumbled upon the thread again.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline tautech
Re: K305D Variable switching power supply
« Reply #57 on: September 21, 2017, 11:18:59 pm »
So the unit I've had for a few years developed a fault.....the amps display shows the mark of the devil: 666  >:D
And a month or two later the volts display went to the other side too.  >:D  :-BROKE
Sourced from the link in reply #45 were 5 pcs GC7137AP, the 24 pin SOP display driver.
They're mounted on the rear of the display PCB and reasonably accessible after the power and data leads for the display are unplugged (mark them in some way) BUT it's a lot easier then just to remove the 3 screws holding the display PCB to the front panel and work on it on the bench. Mentioned is a trap....the power and data leads for the display share the SAME plug and the lengths of their leads enable them to be swapped/reversed.  :--
This pic shows the two leads to the display removed and the display still mounted to the front panel.
The two driver IC's are clearly visible.
I removed the old IC's with a hot air handpiece equipped with a 4mm nozzle and tweezers, then diluted the Pb free solder with leaded solder, chucked some flux down and tacked the replacement IC's into their positions. Note: the silkscreen pin 1 identifier for the IC is under the IC  ::) so care need be taken to ensure you get them the right way around. Of some little help is they share the same orientation so if you get one down and then the other it'll be hard to stuff it up.
There's not much room to drag solder so with a 1 mm pointed tip I finished soldering each pin one at a time.
Success.  ;D
« Last Edit: September 21, 2017, 11:20:34 pm by tautech »
Offline tautech
« Reply #58 on: September 06, 2020, 12:10:34 am »
Got a customers K305D back that was dead !
Really instead it was a dud IEC mains lead and not the one it was supplied with.  :phew:
Easy fix.  :-DD
However after assigning it to SLA charging duties as a check that it was working OK the Amps display showed considerable offset, wouldn't zero with zero load and readings were unstable.  :-//
Anyways, after the obligatory inspection for dud caps, poor solder joints and reseating cables from the current shunt to the display circuitry the offset is gone and and the PSU is working perfectly again.
Both  :phew: and  :-//  :-DD
Offline mava70
« Reply #59 on: February 22, 2021, 08:14:54 am »
this is mine after a kamikaze mods on the gate of mosfets that killed both, now I have 22ohm resistor on the gate and 100mV of noise on the output, I ordered also 2 capacitor for finishing the mods on the mosfet as found on a youtube video, I let you know as soon as they arrives
« Last Edit: February 22, 2021, 08:16:33 am by mava70 »
Offline Johnny B Good
« Reply #60 on: March 27, 2021, 05:21:40 pm »
@mava70
 I guess you're referring to this YT video :-
 I tried this mod just this week on the four digit display version I'd purchased from BG some 16 months ago (virtually identical to the  main board in the three digit version shown - three 330R 5W instead of just two). However, I was a little leery about emulating the ultimate 33R with 47nF caps mod so compromised with 33R and 22nF. Using these values the input power for 320W output went up from 394W to 397W and the IR thermometer readings of the power fets showed just a modest ~4 or 5 deg C rise.
 A week or so later, I decided to test the 33R 47nF combination (I couldn't find any suitable 33nF in my collection of salvage). For exactly the same output power (32V@10.08A), the input power rose to 404W and the IR thermometer readings on the power fet heatsinks went up another 7 to 10 degrees. After 40 minutes, I finally got to prove the efficacy of the overheat protection which simply disables the output until the cooling fan has taken the temperature back down below the cut-in temperature point.
 This gave me the motivation to pick through my collection of circuit boards in my basement which had been awaiting the Round Tuit needed to recover another batch of 'salvage' from which I managed to find just three suitable 33nF 100v mylar capacitors. Swapping the 47nF caps for these 33nF caps reduced the input power to just below the 400W mark, allowing it to run flat out for over 45 minutes without cutting out. In fact I simply reduced it to quarter power (16V 5A) at the 45 minute mark which allowed the fan to shut off after another 5 minutes before cycling to keep the temperature in the safe zone over the next 15 to 20 minutes before I resumed the full loading state.
 This result answers (to some extent) nctnico's then untested speculation of the 10A version being less reliable than the 5A version he'd been playing with way back in 2015. Considering the abuse I'd applied to this 4 digit version, the reliability (so far!) seems to be holding up. Mind you, I entirely agree :( with his thoughts and observations about the safety and EMI/RFI issues (but this is par for the course with most cheap Chinese kit - opening them up to defuse the various time bombs contained within[1] is SOP for any seasoned 'cheapskate' collector of such "Sows's Ears" ::)).
 In this case, turning it into a "Rayon Purse" will be difficult enough and you'd best give up all hope of ever converting it into some facsimile of a "Silk Purse" - it is what it is, a cheap 'n' cheerful bench supply to experiment with less critically sensitive projects or testing the immunity to noisy DC power of kit designed to be powered via a DC input jack.
 As for my own efforts, as well as optimising TheStuffMade gate drive mod, I also threaded about 40uH's worth of small ferrite rings over both output wires between the main board and the banana binding posts for common mode filtering, along with a 470nF 250vac mylar cap at the board end and a couple of 2.2uF 100v mylar caps across the banana binding posts plus about 10uH's worth of ferrite rings over each individual wire to provide additional differential mode filtering.
 I also replaced the rather weedy earthing link wire connection to the C14 PE tag with a toroidal choke to reduce pollution of the mains wiring with common mode RFI and tied the negative to the case ground with a 3k3 1W resistor to suppress the 25vrms 50Hz imposed by the various Y caps linking to the half mains live voltage from the HT rectifier pack down to half a volt (also neatly providing a relatively lo-Z 'static drain' connection). That choice of resistor still permits it to be safely stacked in series with another psu up to 50v (60v at a push).
 These measures reduced the switching spike noise from its original 1.5v ppk down to a "mere" ::) 50 to 60mV at the full 680MHz BW of my 'scope (the 20MHz BW setting reduced this by about another 12 dB), leaving the 'ripple' unaltered (varying between 2 and 14mV ppk depending on voltage and loading). It's still far from being a 'stellar result', more a case of being just "meh" rather than "absolutely horrendous".
 I did try nctnico's Y cap mod to link the output switching noise back to its source in the HT rectifier pack but I couldn't detect any improvement in spite of using a couple of 8nF caps in parallel for "maximum smoke"... er benefit. I think the rather spread out circuit layout, in spite of my linking the centre tap of the secondary to the nearby negative rail of the HT connection to the low side FET's source to minimise unwanted inductance, rather defeated this attempt at reducing this capacitively coupled switching noise between the primary and secondary sides of the transformer.
 I'm beginning to think this switching noise is being magnetically radiated directly from the transformer rather than via just the usual conductive pathways. Fitting a copper shield around the whole transformer to short out leakage flux might provide a significant level of mitigation in this case.
 I might try making up such a copper 'shield' to fit over the transformer to test this hypothesis when I'm next in the mood for yet another modding session. Anyway, I thought it was worth mentioning just in case anyone else fancied trying out this possible solution.
 Incidentally, for anyone looking for a cheap smpsu based bench supply where the cheapest or cheaper option is "The wrong mains voltage type for their region", the conversion from 220 to 110 v mains is merely a matter of linking the junction of the two smoothing caps to the neutral side AC connection on the bridge rectifier or removal of this link to convert a 110v only unit into a 220v unit. Adding this link converts the full bridge rectifier into a half bridge full wave voltage doubler (+/- 170vdc wrt neutral/capacitor junction - a total of 340vdc from the 110vac supply). Removing this link on a 110vac unit converts it back into a full bridge circuit giving the same 340vdc total off a 220vac supply.  This is the standard way to add a dual mains voltage selector switch to smpsus which came into general use with the advent of the IBM desktop PC (and clones) some 40 years ago (and it wasn't a new idea even then!).
 One of the very first things I did with this bench psu was to disconnect the voltage selector from the main board to eliminate the risk of the selector switch being accidentally (or deliberately) moved to the 110v position since I have absolutely no plans whatsoever to operate it outside of the UK.
 I did mark the original connection points to cover the extremely unlikely need to operate it from a 110v supply at a later date. I'd had it in mind that if I didn't, Sod's Law would guarantee that such a need would arise no matter how extremely unlikely this seems (second guessing the Lords Sod and Murphy is a losers' game).
[1] The 'time bomb' in this case being the power fet's heatsinks' tending to lean towards each other to varying degrees of (undesirable) 'intimacy', some to the point of touching each other at the slightest hint of vibration (as a few unfortunates discovered to their cost). All those YT tear down videos provide a valuable service in forewarning the prospective purchaser over what needs sorting out to avoid the "Tears Before Bedtime" effect.
John
