Author Topic: Velleman DVM9912 Teardown  (Read 3921 times)
Offline dumle29Topic starter
« on: June 30, 2015, 01:34:48 am »
Hello there. I've considered shipping dave a Velleman DVM9912 for a teardown, but I don't have 100$ + shipping to spend on that. Therefor I decided to take it appart myself, and try and take some proper pictures with whatever lighting I have.
First of all, the specs of the meter: http://www.velleman.eu/products/view/?country=be&lang=en&id=368124
I'm not entirely sure what more to write, so I will link in an album that I posted on imgur, as I prefer that for image hosting. Do note that most pictures will have a small description under them.
Album: http://imgur.com/a/YD8Qm
EDIT: And a note on the lack of background lighting of the LCD, I can't seem to find any Velleman DVMs that use that PCB, which has the backlight. Velleman is a reseller of other OEMs though, so the original OEM might have a different version that Velleman decided not to rebrand and sell.
« Last Edit: June 30, 2015, 01:36:19 am by dumle29 »
Offline Vgkid
Re: Velleman DVM9912 Teardown
« Reply #1 on: June 30, 2015, 01:58:33 am »
Thanks for the teardown. It is always nice to get a mini review with a teardown.
Offline retiredcaps
« Reply #2 on: June 30, 2015, 05:14:36 am »
Thanks for taking the pictures and sharing.
CEM Instruments is the original OEM for this multimeter.
http://www.cem-instruments.com/en/pro/sort7-1.html
Offline Hydrawerk
« Reply #3 on: June 30, 2015, 12:21:26 pm »
In a CEM multimeter I expected some better fuses for .  :-- :--
But for low voltage bench use it might be OK.
But the construction is definitely better than my own UNI-T UT70A.
« Last Edit: July 02, 2015, 05:37:00 pm by Hydrawerk »
« Reply #4 on: June 30, 2015, 10:43:37 pm »
Ahh, thanks :)
But the construction is definitely better than UNI-T UT70A.
That is certainly my major gripe with this meter :/
