Depending on what you're doing the direct browser based interface is very fully featured.
With older scopes like the 5000/6000/7000, it's dependent on a Java enabled browser which is becoming almost impossible to configure these days due to layer upon layer of well-meaning security protecting us from ourselves.
Very true.
And Java almost wants to update as much as an Adobe Flash player and resets all security settings. RRR
@ Keysight
Well, today I had an application for a client for the Keysight Oscilloscope Mobile APP
It is a simple slow signal on a pressure sensor and bad products have to be documented.
This would be a perfect application for this APP but ....
It seems the app removes all high noise signal and would suggest that all is perfect.
Hmm, how does this happen.
Here are the sample pictures
1. What I see on the scope screen
2. What I see on the iPad screen
Yes, it is a slow 2000X scope but for this clients need it will fit the budget perfectly and should work with the iPad and mobile App.
Can this be fixed
