Hi!
So I want to get a cheap oscilloscope and the use will be only to measure the speaker output of home amplifiers to make sure I am not clipping.
Do notice that I am using not only speakers but tactile devices so going down to 10hz or even 1hz if possible, would be ideal so I can make sure I am not clipping any of those. I was trying the DSO 152 and it seems to not deal with anything under 6hz but not even sure if it was accurate at that point.
Reading that the DSO152 is not highly regarded and that the 154 Pro is a better unit, I wanted to check about the 153 before buying the 154 Pro.
Or does it even matter for my usage?
Thanks!
