Knowing it's been flogged in the past
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
I did a careful study before posting and know that once you buy it, that's all you get.
On all paper and according to LaurentR, it seems that the USB-PD should be present. Firmware is up to date. This one fell through the cracks, probably because of the 2016 build date. The "about" screen shows the enumerated options and each has a license file present on the scope.
Daniel worked on this topic back when the topic was previously discussed. The only change was the creation of the new "application specific" bundles. These, like AERO, AUTO, etc. do need the latest firmware as that firmware will support new options added to the bundle.
Thanks for the replies. I wanted to hear it from the horse's mouth. As before, it's still too bad you can't update the options at low cost but low cost isn't on Keysight's marketing lips anymore.
