Hi everybody!
I got this guy back in 2017 for 44$, and it had been working pretty well until the last week.
Now it seems that its analog part freezes after a few seconds. I made a short video of that:
1. If I let it rest for a while and then turn it on, then for a few seconds, it works normally, shows voltage and other values correctly.
2. Then, the readings freeze and stop changing, even if I remove the probes or connect something else (s.a. the video above).
3. If I then switch the mode, it shows exactly 00000, and readings do not change anymore.
4. If I turn it off / on right after, it shows exactly 00000, and readings do not change.
5. But if I keep it turned off for an hour, then it works, but only a few seconds (see item 1).
I would appreciate any advice on that.
lygte's review for this DMM:
https://lygte-info.dk/review/DMMHoldPeak%20HP-770D%20UK.htmlSince I wasn't able to find the circuit here I'll attach PCB photos from lygte article (back side if flipped for convenience).
