It's been a while since I added the switch and have played with the FLIR and PI a couple of times.
The image hangs up, I don't get any pics or videos on the sd card.
I don't know where there are any options to change configurations or what would need to be adjusted.
I can see the FLIR image in a screen on the desktop but it hangs and flips between 2 screen shots.
This is from Jolly's last build.
Any ideas?
First check, if your cam is set to UVC !!only!! mode (USB mode in hidden menu). Then ssh to the PI and check, if the video device exists:
root@raspberrypi:~# ls /dev/video0
/dev/video0
If you get something like "No such file or directory", check your USB connectivity.
Then try to manually play the video:
root@raspberrypi:~# DISPLAY=:0 mplayer tv:// -vo sdl
Does it appear on the Screen?
I experienced the hangs too. This happens, if I disconnect/tun off the camera while playing video.
