Author Topic: Can't connect to my LeCroy 9354 via RS232 (Scope Explorer)  (Read 1235 times)
Offline exit_failureTopic starter
« on: June 30, 2018, 09:41:49 am »
I tried to connect to my LeCory 9354AM via RS232 with LeCroy's Scope Explorer. The 'scope has the RS232 hardware option installed. I tried using the pin header on my mainboard and a USB adapter. Both the Scope and my RS232 adapters are set up tu 19200 baud rate, 8 data bits, no parity, one stop bit. I'm using Scope Explorer 2.25.0.0 on Windows 10 64-bit (latest version).
Neither the automatic detection nor manually adding the scope work. When I add it manually the status reads "Dead".
I found some people here who successfully use Scope Explorer but unfortunately no information about what the problem might be in my case.
Is there anything I'm overlooking?
« Last Edit: June 30, 2018, 09:43:47 am by exit_failure »
Offline Mr Nutts
Re: Can't connect to my LeCroy 9354 via RS232 (Scope Explorer)
« Reply #1 on: June 30, 2018, 10:03:06 am »
Do you use a straight cable or a null modem cable? In any case, try the other  ;)
The following users thanked this post: exit_failure
« Reply #2 on: June 30, 2018, 10:45:17 am »
That did the trick. I had to use a null modem cable. Thank you.  :D
« Last Edit: June 30, 2018, 11:04:59 am by exit_failure »
