Author Topic: Can you help me identify a connector?  (Read 11207 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
« on: March 29, 2014, 04:27:11 am »
Hi everyone,
I am trying to make a power supply for my Agilent active probe for spectrum analyzers:
http://www.home.agilent.com/en/pd-1000001990%3Aepsg%3Apro-pn-85024A/high-frequency-probe-300-khz-to-3-ghz
The problem is that it has a power connector (female) with three pins. On the side of the spectrum analyzer there is a male version of this connector. For the life of me I can't find what type of connector it is so I can purchase one. If anyone knows, I would appreciate it. I have used this probe before in one of my videos with the Rigol DSA.
Cheers,
Online Vgkid
Re: Can you help me identify a connector?
« Reply #1 on: March 29, 2014, 04:47:18 am »
It looks like a Neutrik D-series XLR connector, does it have a locking mechanism?
I'm going by the users manual connector picture(not very helpfull), can you provide a picture?
« Reply #2 on: March 29, 2014, 04:53:51 am »
My friend, you seem to be pretty close! I have attached the pictures.
Offline HP-ILnerd
« Reply #3 on: March 29, 2014, 06:56:24 am »
Hugoneus:  Are you going to make a video of any this?
One vote for "yes" right here, if you are soliciting them...
Offline miguelvp
« Reply #4 on: March 29, 2014, 07:52:44 am »
Page 7-6 has the voltages
http://cp.literature.agilent.com/litweb/pdf/85024-90031.pdf
There is a Power Probe Connector to Banana Plug part number 85024A-001
http://www.transcat.com/catalog/productdetail.aspx?itemnum=85024A-001
$164.00
This link shows a picture (included below) of the adapter that includes the connector (but it doesn't really show it)
http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1731516&nid=-11143.0.00&id=1731516
alternate part number 87405-20012 (5X5 part number)
http://www.metrictest.com/product_info.jsp?mfgmdl=HP%2087405-20012(D)
$ 266 refurbished
They recommend using Agilent E3620A, E3630A or the E3631A, DC Power Supply for the adapter to power the probe.
but I can't find the datasheet to get the actual connector.
---- now reaching a bit because they might share the connector with HP probes-----
page 2-3 of this doc seems to have the same connector but the HP probes came with the power already attached.
http://cp.literature.agilent.com/litweb/pdf/41800-90010.pdf
http://www.home.agilent.com/upload/cmc_upload/All/EPSG087227.pdf?&cc=US&lc=eng
Most promising connector picture here (2nd image attached). But now I'm reaching.
https://www.artisantg.com/TestMeasurement/54576-49/Agilent_HP_83400_60005_DC_Cable_Probe_Power_
« Last Edit: March 29, 2014, 07:54:45 am by miguelvp »
Offline cyr
« Reply #5 on: March 29, 2014, 08:14:18 am »
The service manual for my SA (8562E) lists the probe power connector as HP part no 5060-0467.
Seems to be available at parts.agilent.com for ~30 bucks.
Pic:
« Last Edit: March 29, 2014, 08:16:00 am by cyr »
Offline miguelvp
« Reply #6 on: March 29, 2014, 08:30:31 am »
Does the female connector reach to the male connector on the side?
I know silly question but worth asking :)
Offline miguelvp
« Reply #7 on: March 29, 2014, 09:02:24 am »
I mean on the first document I linked:
It describes the power connector body to be part number 5060-0466 and the connector sleeve to be part number 5040-0494 but they should be already on the probe and hopefully it reaches the connector on the side.
Otherwise the connector body cost $45 for the female and cyr posted the link to the male one.
http://www.home.agilent.com/myagilent/faces/partDetail.jspx?partNumber=5060-0466&imageStatus=YES
The connector sleeve costs $139!!!!
http://www.home.agilent.com/myagilent/faces/partDetail.jspx?partNumber=5040-0494&imageStatus=YES
I'm attaching the image of the female body connector (the one that costs $45) part number 5060-0466
Again, the base of the probe shows the power cable that might reach your connector.
The banana adapter is for external power but should have the same connector.
But since you want to make a power supply for it, I would go with the part that cyr posted or buy the banana plug adapter linked on the previous post for more ($164.00)
Also available from parts.agilent.com for $316.00!!!!
http://www.home.agilent.com/myagilent/faces/partDetail.jspx?partNumber=87405-20012&imageStatus=YES
« Last Edit: March 29, 2014, 09:19:15 am by miguelvp »
« Reply #8 on: March 29, 2014, 04:48:35 pm »
Thank you everyone, much appreciated.
They charge so much for a such simple cheap connector. I am tempted to just craft one out of plastic by hand. Or mold one using the male connector and some epoxy.
Online free_electron
    • SiliconValleyGarage
« Reply #9 on: March 29, 2014, 04:58:45 pm »
that is a custom connector made for HP. buy it from hp or , get a probe power supply box of ebay for 50$ and scavenge the connectors from there.
if youneed the cable part you are shit out of luck. you can only hope to find a broken probe and salvage the cable from that.
Offline miguelvp
« Reply #10 on: March 29, 2014, 08:59:36 pm »
The price point probably has to do more with being obsolete than the manufacturing cost at this time. And as time passes they will ramp up the price just to compensate for the storage cost and low production runs.
Then again, a 3D printer might do the job.
And just noticing who you are, you could use your connections (pun intended) to get the banana power adapter 85024A-001 or 87405-20012
@free_electron, HP has been Agilent for quite a while. And you probably already know that :)
« Last Edit: March 29, 2014, 09:03:31 pm by miguelvp »
Offline CrazyFin
« Reply #11 on: April 14, 2016, 08:12:47 am »
Hi
I am aware of this thread been "silent" for more than 2 years but I was unsure if a new topic would be better instead of posting here about this good info I have found out on this connector issue.
I discovered that the same connector that is on the spectrum analyzers where you connect the HP 85024A HF probe too also exists in the probe power supply HP 1122A. I found out that the part number for that internal connector in these power supplies is 08711-60037 and when searching around for that part I was lucky enough to find an eBay seller selling two of those connectors for 17 USD each!  :-+
So if you are in the search for this special connector you might either try to find this connector 08711-60037 or find a broken HP 1122A (or similar) probe power supply from where you can pull out the connector.
The 08711-60037 looks like this:
Offline avvidclif
« Reply #12 on: April 14, 2016, 03:44:26 pm »
Why not just find a broken 1122 and fix it?
Clif Holland KA5IPF
www.avvid.com
Offline richhas
« Reply #13 on: March 25, 2017, 04:56:48 pm »
Hi, I have the same probe and the same connector issue. May I ask what you ended up doing?
Thanks,
Rich
Offline ruairi
« Reply #14 on: June 30, 2017, 03:40:48 am »
I've been looking into adding an active probe and the idea of a used 85024a and external power supply appeals.
I looked into the Keysight adapter cable and the price is now over $400!  See screenshot attached.
If I get the probe at a reasonable price is there a reason not to just cut the power connector off and add my own bananas? (I've got an R&S RTB so I won't be using with HP/Agilent/Keysight scope anytime soon.
Offline Richard Crowley
  • KJ7YLK
« Reply #15 on: June 30, 2017, 03:59:36 am »
Wow, at that price I would make my own connector using three machine-screw female pins and some moldable plastic like https://sugru.com/
Offline ruairi
« Reply #16 on: June 30, 2017, 02:47:10 pm »
Yes, needless to say that option is off the table!
I'm happy to cut the power cable on the probe and terminate with bananas for a bench supply.  Is there some technical reason that people don't know this?  Bar respect for a nice probeā€¦
Cheers,
Ruairi
Offline Dino KL0S
« Reply #17 on: August 23, 2017, 04:55:05 pm »
Has anyone ever found a source for the female connector that mates to the front panel? I have a Rigol DSA1030 that has a three pin male "probe power" port on the front that I'd like to use to power a homebrew high impedance probe. Unfortunately even Rigol doesn't know the specs for the connector (couldn't believe they didn't have the part/port documented somehow)...it appears that it may be a "Lemo" brand connector of some kind.
Offline OldGeo
  • Country: ru
« Reply #18 on: December 14, 2021, 04:40:14 pm »
That is name of.
1349483-0" alt="" class="bbc_img" />
