The TPP0500 (10x 500MHz), TPP0502 (2x 500MHz), TPP1000 (10x 1GHz) are specially designed probes from Tektronix that interact with our pre-amplifier front end chipset. This enables you to auto-compensate (no need for an adjustment tool), and you only need to compensate it once per channel, and the calibration data is stored on the instrument. Plus you get industry leading low capacitance loading (3.9pF) and up to 1GHz system bandwidth at the tip of the probe. Honestly its the best passive probe on the market!!
Because of its greatness and dependency on the pre-amp, it is only compatible with Tektronix oscilloscopes that have the VPI probe interface. This would be compatible on the:
New instruments!
3 Series MDO
4 Series MSO
5 Series MSO
5 Series MSO Low Profile
6 Series MSO
6 Series Low Profile Digitizer
Or legacy instruments...
MDO3000
MSO/DPO4000B
MDO4000/B/C
MSO/DPO5000/B
