Author Topic: Video National Instruments VirtualBench Review, Teardown & Experiments  (Read 4394 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
A close look at the VirtualBench lab-in-a-box from National Instruments:
You can watch the video here: [1 Hour & 1 Minute]
youtu.be/8N2MhA9N77I
More videos at The Signal Path:
http://www.TheSignalPath.com
« Last Edit: August 23, 2015, 04:49:30 pm by Hugoneus »
Offline BFX
  • Country: sk
Re: Video National Instruments VirtualBench Review, Teardown & Experiments
« Reply #1 on: August 23, 2015, 05:35:11 pm »
Thank you for next nice video :-+
I'm little disappointed from quality of cables.  :--
And one function can be very helpful: sweeping of function generator.
I'm waiting for software upgrade  :popcorn:
Offline HighVoltage
« Reply #2 on: August 23, 2015, 07:35:53 pm »
Although this is something I would not consider for my lab, I really liked your review.
You have always a really great balance between review, repair and experiments.
Thank you for the effort you put in to your videos.
Offline Dr. Frank
« Reply #3 on: August 24, 2015, 05:42:56 am »
Nice, interesting video!  :-+
Frank
Offline rx8pilot
« Reply #4 on: August 24, 2015, 06:07:57 am »
Can't wait to see this one. I have made the commitment to Labview but have not settled on all the hardware. I did look at this system and was wishing there was something between this and a full PXI chassis which can gt really expensive.
« Reply #5 on: August 25, 2015, 04:31:36 pm »
As I mentioned, if you like to play around with LabView this would be a fun instrument to play with.
Offline Neganur
« Reply #6 on: September 20, 2015, 12:42:10 pm »
Finally got my quote from NI (the instrument has been on backorder for a while now). It's 2.5k EUR (USD 2,830) after VAT and I think I will say no.
I think I would have bought it for 2k EUR but 2.5k amplifies the points I did not like about it a little too much.
Originally, I was looking for a programmable three channel power supply, and since many of my projects are of embedded nature the digital I/O and mini-logic analyser were a welcome feature. Other projects are of such nature that I need to power a device and verify current consumption, measure voltages at test points, switch some I/O lines to change an RF path, maybe send a SPI command and make an amplitude /phase measurement between two LF signals (i.e. I/Q).
The VirtualBench feature list is really a good match for what I have in mind and it's such a nice form factor & can be controlled with e.g. C/Python/Labview. But to use some of the features, like using the I/O to talk SPI or I2C, you really have to use custom scripting since the VirtualBench application itself doesn't support it (yet).
My humble list of gripes:
  • Some scope measurements are only available via the VirtualBench application (waveform measurements, math)
  • It sounds like the memory is shared between the LA and the scope? enable several channels and you may end up with 4kSa (but this might be rare)
  • No sense wires. Yeah I can probably hack it to provide it but damn, there's already no binding posts on the front panel - surely a wider header for the PSU connector would have been possible.
  • Can't enable/disable the PSU channels separately; at least I did not see it in the C or LabVIEW API.
  • The 25V channels can only supply 500mA. (Now, I don't need 5A but 1 A would have been more useful.)
Scope and function generator are useful addons and I suppose if you're setting up some data logging with it you can still use your main scope etc.
For now, I think I'm better off buying a separate PSU since the VirtualBench just doubles a lot of the instruments I already own without adding anything or replacing completely.
A good programmable triple channel PSU costs somewhere in the vicinity of 1-1.5k EUR and the VirtualBench doesn't do the PSU part well enough in my opinion.
