needed a two channel complementary PWM with dead-time insertion to do some testing on a halfbridge switch-mode power stage.
although the SDG6000X (or SDG6022X for that matter) has two channels that can be set up for PWM individually, there's no straightforward way to actually program them to do push-pull with dead-time
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
(hey SIGLENT: hint, hint...)
thought i'd share the setup with you. see below a one-page cheat sheet. if you're too lazy to set it up manually, use the attached XML status instead.
(you have to change the file extension from *.txt to *.XML)
any suggestions welcome!
