...white polystyrene tiles are glued into shape and fitted on top of blue pyramidal absorbers. ...
Are those just impact protection, or do they actually serve an RF purpose?
The white tiles are made from polystyrene which Nick tells me is completely transparent to RF so they offer no technical/performance benefit to the chamber characteristics. They are added purely for protection and decorative purposes. They make the chamber brighter to work in and protect the tips of the foam absorbers.
Currently, all the pictures I've taken inside the chamber are lit with the actual lights that were intended to be installed in the chamber (I thought they were temporary work lights). They were plugged into a temporary extension chord because the chamber hasn't been wired by the electrician yet.
The lights were trac pro 70w SON lights which are sodium based and give a very yellow/orange light similar to street lights here in the UK. I asked Global to replace them with something whiter because it was too gloomy inside. Global don't normally use SON lights and were happy to replace them.
The final lights (metal halide) are still wired up using a temporary connection but give a much better light.
See the pictures below:
Tuesday 22nd April (After bank holiday)
Lights changed to metal halide, ferite tiles added to floor and pyramidal absorbers placed on top of those. Nick arrives to begin next stage of testing (All the pictures below are from Nick and show the test setup he is using. The equipment is his as well)
White tiles fitted on top of all side walls, with tiles missing in some areas (Global sent a full complement, but murphys law got us). Replacement tiles were sent down free of charge. Global had to deliver some of Nicks test gear so they sent the replacement tiles in the same shipment.
The picture is taken at the corner where the door is and is looking towards the back of the chamber where my antenna will be placed.
Here's another picture showing the same view. This time you can see a walk way on the right that leads up to the antenna area.
The ferrite tiles and pyramid absorbers on the floor are not fixed in place. This allows us to move the floor around.
Nicks tests will assume the floor is going to stay in this position. Global EMC call this an offset chamber which means the antenna, floor absorbers and EUT are not on the center line of the chamber. This allows us to have the walk way on the right. Nick will check to make sure we can establish a uniform field around the EUT.
Another view of the antenna area, taken from the EUT position.
Final picture showing one of Nicks setups. This time taken from the antenna area, looking towards the EUT area.
