I just started getting interested in higher quality DDMs about 3 weeks ago. I've been reading many reviews and watched lots of videos. Just joined this forum today. I've had an Innova 3320 for I believe over 10 years. I has not gotten much use. However, I am starting to delve in electronics, and the limitations of the Innova 3320 are very apparent. I figured a descent quality multimeter would be a good investment. My current needs are mainly accurate DC voltage readings in the 3.5v to 8.4v range, continuity test, and testing capacitors. I've played with a Fluke 287 for the past 2 weeks. I understand that it is among the best portable DMM in the market with very high accuracy, but I don't find it fun to use. The 3 second boot up time does not bother me too much, but the display is not easy on my aging eyes with the low contrast, small digits size, narrow viewing angle, and the ghosting of the last 1 to 2 digits. It is also pretty big on my work bench, and has a pretty high center of gravity sitting on the stand, so I am concerned that it may be too prone to tipping over and damage the protruding knob or the screen. That plus the fact that I do not have immediate need for top-of-the line AC measurements and graphs, I may be returning this Fluke 287 to Amazon. I already ordered a Fluke 87V and a Brymen 869s to compare against the Fluke 287 before I make a final decision, but I anticipate keeping both the Fluke 87V and the Brymen 869s, and returning the Fluke 287.
I look forward to learning from all the experience folks here. Thanks.
