Author Topic: Bunch of keysight U1252B meters around  (Read 151323 times)
Offline Lincent
  • Country: ru
Re: Bunch of keysight U1252B meters around
« Reply #600 on: April 30, 2019, 04:55:30 pm »
I put the Li-ion battery purchased on Aliexpress. Measured capacity 650 mah.
Built-in PCB protects against overcharging at 8.44 volts, and against overdischarge.
It is perfectly charged by the built-in charging of the meter U1252A and there is no danger of overcharging.
In the photo the charge limit and the type of viscera.
« Last Edit: April 30, 2019, 05:16:58 pm by Lincent »
Offline timelessbeing
« Reply #601 on: April 30, 2019, 09:25:25 pm »
Thanks. What was the price? Can you give a link please?
Offline Lincent
  • Country: ru
« Reply #602 on: May 01, 2019, 12:09:16 am »
I took a year ago, 2 pcs at a discount for 10 USD this product. Now the price is about 7 USD for 1 pc.
I found my review to the seller for this purchase:
600-650mAh battery instead of the declared 1000mAh. This is very bad. In the photo measurement. Discharged with current 150 mA fore disconnecting with built-in protection at 5.72 volts. Charged with an initial current of 150mA with a voltage of 8.47 volts. When charging / discharging 8.4-6.0V, the capacity will be approximately 0.6Ah, so be careful that it does not bulge. Protection shuts off charge at 8.52 volts. Overcharge / discharge protection works. Inside there are two cans of Li 722337 and a protection board. In general, everything is fine, except for capacity. Buy and return on the dispute about 40%.
« Last Edit: May 01, 2019, 12:35:31 am by Lincent »
