Finally arrived
3 and a half weeks and one lost to the USPS.
Aug 2013 cal, Agilent branded with v 217 firmware. Newer would have been nice as there will be no manufacturer warranty left but I'm not complaining. Not much point in registering with Keysight.
Accuracy seems fine, it agrees (to the last digit) with my Keithley 2015 that my DMMCheck has drifted high (currently measuring 5.0012V), it looks as though the Tenma 72-7732A that I bought from Top Loser is reading a bit low at 4.996V (though technically still within spec which is 0.05% plus 5 counts).
The included power supply (24V @ 2.5A) appears to be total overkill for charging a 250mAh 8.4V NiMH battery, and who thought having the PSU plug into the current range was a good idea?
Packing similar to everyone else, in my case a sad bit of bubble wrap inside the USPS box which was insufficient to stop the Agilent box from moving around.
