Im going to buy things I know I need and I know what quality i need for each item based on it's importance. I'm probably going to spend the most on an oscilloscope because I know how important it is. Probably going to spend right around $1000 for one. Im eyeballing a Rigol DS2102A. A power supply, not sure yet. I'll have to read through your post carefully and see. I was considering getting a RIGOL DP1308A power supply. I dont need anything more than 25v, right now at least. The signal path reviewed it and he liked it. So that was good. I have to watch his other video on it though. It is a programmable supply. I know you said not to worry about getting one of these. We'll see what happens.
There is nothing wrong with spending money or buying good tools. It's a personal decision. The DP1803A has a retail price of $908 and is an 80 triple output power supply. I haven't heard any bad things about that supply, which is rare for Rigol products.
To give you an idea of what is out there, I just purchased a Keithley 2280s power supply (factory refurbished). It was ~$1300. It has a built in 6.5 digit meter and can measure current down to
10 nanoAmps. But it's only a single channel 20V/6A supply. I'm going to use it on some battery powered embedded projects.
I'm not recommending this meter to you, but if you go slow and have a list of things you want you can buy a lot better with not much more money. Keep an eye out for sales. Rigols do go on sale occasionally 25%-35% off.
Quite frankly, I think you'll be happy no matter what supply you get or if you build your own.
The best advice I could give is to take the time to research what makes one power supply better than another, and make your decision. Same for the other equipment.
http://www.bkprecision.com/support/downloads/power-supply-guide.htmlhttp://www.delftek.com/wp-content/uploads/2012/04/HP-power-supply-handbook.pdfI can't find the other ones, but there are some guides and appnotes from the other manufacturers. When you become an EE, you are going to be doing this a lot- look at requirements, evaluating, shopping, rinse and repeat.
