« Reply #12 on: June 09, 2015, 04:14:48 am »
Typical input bias current 1.5 pA, maximum 40 pA. Not low enough
You're not making electronics for an automotive environment here ... specs over temperature range are irrelevant.
Input voltage range -0.1V to +3V Not practical as a buffer
You read the specs for 5V single ended supply, not the 16V supply (also you should feed it ~-2 to +14 to get better performance around 0).
The relevant bias current information for you is figure 14 page 7 (0.1 pA typical at 25 degrees Celsius). Worst case is irrelevant, test the IC and if it doesn't perform well enough try another till you get a typical one.
Which datasheet has input bias of 0.1 pA typical?
Logged
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220, Rigol DG1032 PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
