Author Topic: Remote switching (now with APC ;o)  (Read 2140 times)
Offline davorinTopic starter
« on: August 21, 2016, 03:33:08 pm »
As I have most of my equipment behind the desk in a Ikea shelf...powering them on is not always easy...for example if some gear has the power switch in the back (o;
Used to do the switching before with those Netio-230C smart switches...but since incorporating them into a scripting language wasn't easy...I switched to the good old AP9212 switches with SNMP/Web management card installed (AP9606).
Those switches are more me also a good way to measure power-on/power-off automated scenario...
There is even a simple PHP class for controlling them:
https://github.com/trendchiller/AP9212
But as I like also desktop applications...I started a quick hack in Xojo....though I am bit rusty since I haven't used it for a long time (o;
What's missing is getting the outlet names and status via SNMP during startup....but surprisingly the old RealBasic pbsw-SNMP class still works ;-)
And yes...some preferences dialog to enter the IP addresses of those switches and create individual tabs for them (as I have currently 5 AP9212)
This guy sells plenty of those if you need power switch automation like I do:
http://www.ebay.de/sch/gucky74/m.html?item=122092898053
Think I would need also some more as 40 outlets are never enough (o;
Re: Remote switching (now with APC ;o)
« Reply #1 on: August 21, 2016, 04:18:05 pm »
Lots of unoptimized, straight code..but works for reading all outlet descriptions and switch state (o;
Haven't tested other builds as Xojo supports OSX, Win and Linux....well...Webapp makes no sense for Xojo (o;
Offline bingo600
« Reply #2 on: August 22, 2016, 02:14:47 pm »
Where did you get the cables from , the PDU-->Device 230v cables ?
Mine didn't include any cables
I'm just using snmpset under linux to control the outlets.
/Bingo
« Last Edit: August 22, 2016, 02:18:20 pm by bingo600 »
« Reply #3 on: August 22, 2016, 02:32:12 pm »
One cable was always included with the Netio-230C....and the other cables I got from the same reseller I got the 230C from...
But see that Ebay lists lots of them.....just search for C13 C14 cable (or Kabel ;o)
http://www.ebay.de/itm/Kaltgerateverlangerung-1-8-m-Stecker-auf-Buchse-C13-C14-schwarz-NEU-/252508649860
