Author Topic: Picoscope Hack  (Read 16411 times)
Offline b_force
    • One World Concepts
Re: Picoscope Hack
« Reply #75 on: June 30, 2023, 12:53:36 pm »
I can verify that there is at least one Picoscope that doesn't follow this hacking recipe.    :-DD
I have a 2204a I purchased in 2016.  The hardware version is 17.  Anyway, increasing byte 0B by 1 and decreasing byte 1B by 1 did not do the trick.  I have tried a bunch of other options as well, but so far all of the trials have resulted in a device that the picoscope software does not recognize.
Edit:forgot to say that i am trying to turn it into a 2205a, which has identical hardware.
The eeprom on my 2204a is definitely different than the one discussed on the sigroc page.  For example, B7-D9 and F8-FD are all non-zero.  I have of course mucked with some of these bytes as well - especially F8-FD that look less like cal data than some of the other areas.
I am very inexperienced when it comes to this kind of stuff, so any suggestions you-all might have would be helpful.  For the trial and error approach I have been using so far, it might be time to write a python script to automate it more.
In any case, it has been fun to play with this.
cheers,
jason
We meet here as well! :D :D
I am still curious how this adventure ended up and if/how it works with the 2000 series? :)  8)
Offline jasonRF
Re: Picoscope Hack
« Reply #76 on: July 01, 2023, 03:59:43 pm »
I was never able to get the unit upgraded, although there is at least one person here who did change a 2204a to a 2205a.  My 2204a isn’t used very much anymore so it really doesn’t matter to me.   It was just fun to poke at.   I would brute force it with a python script using an arduino and the pico api (and I even started to), but everytime you test to see if the api recognizes the scope you hear relays clicking.   After a  hundred unsuccessful attempts I killed my script since didn’t want to wear out the relays for no good reason.
Jason
Offline MiDi
  • Country: ua
Re: Picoscope Hack
« Reply #77 on: December 19, 2023, 07:07:50 pm »
Had no problems to hack 2204A (HW Version 17, cal 2023-04-17) to 2205A using fx2tool as described in the Saleae thread.
Save to eeprom.hex:
fx2tool -B -d 0CE9:1007 read_eeprom -W 1 0 256 -f eeprom.hex
Changed byte 0B from 1A to 1B and reduced the serial by one (bytes 13-1B) and used HEX file checksum online calculator for correcting checksum at the line ends.
Upload from eeprom_hack.hex:
fx2tool -B -d 0CE9:1007 write_eeprom -W 1 -f eeprom_hack.hex
Replug the scope, otherwise it will not be recognized.
It's my friend from a while, to be more precise Cypress USB Console + EZ-USB Interface (but I guess you already know).
It happens that maaany years ago I developed a 14bits ADC streamer based on commercial PATA HDD external case (Cypress CY7C68013 inside) in conjunction with a Labview application, this joke was able to push flawlessly 16MS/s x 16bits (32MB/s) toward a medium windows PC of the time, with some real time computation and disk logging.
Now you can understand why I smell BS if I read that the 2204A streaming mode is limited to 1MS/s due to the fact that the board has a buffer on only 8Kpts (inside the FPGA).
I had no FPGA and no buffer, but the system worked like a charm, so I would say that the 2204A sounds like a cripple fest.
The limit with current SDK is 150ns/6.67MSPS for continuous fast streaming for one CH, but sometimes it drops a couple of samples.
« Last Edit: December 19, 2023, 07:27:46 pm by MiDi »
The following users thanked this post: b_force, egonotto, unseenninja
Offline b_force
Re: Picoscope Hack
« Reply #78 on: January 17, 2024, 01:57:46 am »
Save to eeprom.hex:
So I assume the 2204A can only be "upgraded" to the 2205A ?
I still really like the picoscope software, so much better than my physical scope.
It's just that they are so pricey :(
Online coromonadalix
Re: Picoscope Hack
« Reply #79 on: January 17, 2024, 03:34:42 am »
at the price we paid a 3406d   i would have bought an huge siglent model  loll
lost  my arms and legs  loll
picoscope newest sw  need some improvements,  but getting there
« Last Edit: January 17, 2024, 03:36:20 am by coromonadalix »
Offline unseenninja
Re: Picoscope Hack
« Reply #80 on: June 12, 2024, 07:08:47 pm »
--snip--
Thanks for the clear instructions. Worked a treat for me too!
Offline TomKatt
Re: Picoscope Hack
« Reply #81 on: June 12, 2024, 08:29:54 pm »
I’d guess that Rigol and Siglent have a much larger market share and likely get better component pricing as a result.  Their manufacturing costs are probably also lower.  That said, they likely are able to manage lower profit margins on much of their product line as a result.
Another consideration is that Pico needs to sustain the software development that makes their products so valuable.  A hardware BOM cost comparison probably doesn’t provide the whole picture.
I think that Pico’s software environment would suit my scope needs better than stand alone desktop products - it seems very handy for observing and finding issues with longer acquisitions.  Too bad they are out of my financial budget.
« Last Edit: June 12, 2024, 08:34:25 pm by TomKatt »
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Offline MiroS
Re: Picoscope Hack
« Reply #82 on: June 14, 2024, 07:16:23 am »
--snip--
(Attachment Link)
My serial is ending with zero J****/**30 , if I change it to  J****/**29 - hack does not work, if I decrease  last digit in number J****/**30  by 1 so  it will be last digit hex 29 so not a  number anymore ( 0 is hex 30).
Is there any way for such case?
« Last Edit: June 14, 2024, 08:20:28 am by MiroS »
Offline XanderL73
Re: Picoscope Hack
« Reply #83 on: July 12, 2024, 07:27:59 pm »
Hi all,
I very new to this side of tech. I think I have libusb and fx2tool setup properly on my macbook. When I connect my picoscope 2405a, I see in my system information that it has pid 1016. Now when I sent the command:
fx2tool -B -d 0CE9:1016 read_eeprom -W 1 0 256 -f eeprom.hex
I get the response:
Command not acknowledged (wrong address width?)
fx2tool -B -d 0CE9:1016 read_eeprom -W 2 0 256 -f eeprom.hex
this works and writes the file.
After a bit of puzzeling and reading through all the posts again I figured out which numbers to change (I used a straight text editor) and uploaded the new file with:
fx2tool -B -d 0CE9:1016 write_eeprom -W 2 -f eeprom_hack32.hex
Did a readback and found the new numbers in place.
Next I started picoscope 7 and it finds a 2406B, with the serial 1 lower than before, but it also shows a red X and says failed.
So I hope that the great folks on this forum can nudge me in the right direction. I just want to see what is possible. Even upgrading it 1 step from 25 to 50 Mhz would be welcome.
At least loading the original backup back, did restore the scope to the factory settings and it works in picoscope 7.
« Last Edit: July 12, 2024, 09:38:35 pm by XanderL73 »
Offline hugo
Re: Picoscope Hack
« Reply #84 on: July 13, 2024, 02:07:10 am »
We do know that some of the 2204A models can be upgraded to the 2205A, however I do believe that 2406B model is a totaly different species (different size and hardware) so no upgrade will be possible ...
Offline narkeleptk
    • Youtube
Re: Picoscope Hack
« Reply #85 on: July 13, 2024, 03:16:53 am »
Con confirm. I have a 2205 and 2206 and they are completely different despite the external case looking similar.
Offline XanderL73
Re: Picoscope Hack
« Reply #86 on: July 13, 2024, 06:56:10 am »
Glad to hear that it is hardware related. It at least means that I most likely understood how it should be done, it just isn’t possible. The upside is I learned a new skill ;)
I bought the cheapest 4 channel basically for myself and have at the moment no specific use for higher bandwidth. It is mainly to see if it works better than my old tiepie and labnation. That last one had some serious potential, but the company never continued development of the software other than bugfixes. The tiepie I got like 15 years ago at work, but I believe it is only 2 channels and 5 or 10Mhz and is now a bit outdated for the newer hardware we use. Since it still works it is a bit hard to convince the boss that we need something new. In the latest hardware we delivered we use encoders with 4 signals, hence the 4 channels. I had one encoder that turned out to be wonky, but to prove that I had to make many measurements by combining 2 channels at a time. With 4 channels I can check this in 1 go. If I can order a new one for work I’ll ask for a 50Mhz, 4 channel (that would be a B-version).
Offline MiDi
  • Country: ua
Re: Picoscope Hack
« Reply #87 on: August 03, 2024, 11:18:47 am »
--snip--
(Attachment Link)
No need to change the last digit, just change one digit of the SN.
