Loading [MathJax]/extensions/Safe.js
Author Topic: Brymen meters "beep" on diode check?  (Read 15774 times)
Offline noideaTopic starter
« on: March 27, 2017, 04:32:10 pm »
I recently bought a BM257'S to replace an old Fluke 12 that I broke the display on. There's a lot of things I like about the meter but one that I'm not loving is the lack of beep function when using diode check mode. I've read the manual but there doesn't seem to be an option to enable it.
Does anyone else know if other models of Brymen meters are the same? I'm thinking of getting a BM 878 as I like the low resistance earth continuity measuring capability as well the insulation test functions, but would prefer an audible diode test function.
The following users thanked this post: 2X
Online JPortici
Re: Brymen meters "beep" on diode check?
« Reply #1 on: March 27, 2017, 05:16:11 pm »
which meters beep on diode check?
Offline DaJMasta
    • medpants.com
« Reply #2 on: March 27, 2017, 08:53:59 pm »
My BM867s does not beep while diode checking.
« Reply #3 on: March 27, 2017, 10:54:03 pm »
Maybe I should have clarified it better, beep on short circuit ie less than 0.1v
Every Fluke I have ever used does it and so does the Keysight U1252b  I bought recently. When you are working on something in the field and your meter can't always be in the best position to focus on the screen and also where you are placing your probes it's very handy.
« Reply #4 on: March 27, 2017, 10:56:27 pm »
Ta I found a copy of the BM878 manual last night and read it cover to cover and came to that conclusion,  maybe it's a Brymen thing not to.
Online IanB
« Reply #5 on: March 27, 2017, 11:09:18 pm »
Are you saying that if you touch the probes together in diode check mode you get a beep to warn you that you are not making proper contact with the diode terminals or that the diode has failed short circuit? If so, that does seem like a useful feature.
Offline mstck
« Reply #6 on: March 27, 2017, 11:49:15 pm »
The Fluke 87V and  the U1252b emit a beep when the diode is connected in the forward bias direction. They also beep if the probe tips are shorted. Some people use this mode for continuity checks.
The following users thanked this post: noidea, 2X, lisafig
Offline james_s
« Reply #7 on: March 28, 2017, 12:41:02 am »
This is something I miss in my Fluke 87. I had an older Fluke, I think it was a 29? Anyway it had a fantastic diode test function where a good junction would give a short beep and a shorted junction would give a continuous beep. It was great because I could test a bunch of diodes and transistors without looking up at the meter. I don't know why Fluke changed this, if it's possible to enable on my 87 I'd love to know how.
Offline BurningTantalum
« Reply #8 on: March 28, 2017, 01:36:49 am »
As I am a Fluke 77 and 79 man I had no idea that Fluke had changed this extremely useful feature. I have recently been looking to update to a newer Fluke DMM but may have to look around elsewhere- a narrow escape as it would not have occurred to me to check this feature in the specs (if indeed it is stated or not)
Does any new meter have this 'short beep on PN junction' feature?
I use this feature daily.
BT
« Reply #9 on: March 28, 2017, 01:44:02 am »
This,
I work on inverter driven air conditioners and quite often the meter is hanging off the unit or off to one side to where the main circuit boards are. You are poking round the board testing the diode bridges, power transistor module and various other diodes and transistors, so getting the audible short circuit confirmation beep is really useful when you are concentrating on where you are probing.
I also do a lot of over the phone technical support to other technicians, I always ask what meter they are using. I get them to set their meter to diode test function and tell me what readings they get with open and closed probes as most of them have never used or understand what it's used for. In Australia Fluke's are pretty common and most times I can tell by the beep I hear over the phone the state of a component before they have even told me what the reading is.
The following users thanked this post: xavier60
« Reply #10 on: March 28, 2017, 01:47:08 am »
I was training some techs last week, one had a 77 and the other a 179 they both "beeped"
I know that the 116 / 117's also do it, as most techs I talk to have them.
My 196c doesn't do it but the multimeter is really just a token function.
Offline BMack
« Reply #11 on: March 28, 2017, 05:20:37 am »
I can't stand when meters don't beep on diode check, it's why I almost instantly regretted getting a 87III and bought a second 87V.
« Reply #12 on: March 28, 2017, 08:32:14 am »
Just to clarify:
Can anyone list which meters have the short beep for a good PN junction.
Also which meters have ONLY the continuous beep for a probe short (less than a nominal mV) and no beep at ~500mV.
BT
Offline Wytnucls
« Reply #13 on: March 28, 2017, 11:33:45 am »
Few meters have an acoustic warning signal on diode test.
A continuous tone for a short and a lone beep for a good PN junction:
Fluke 289 287 87V 233 179 177 175 117 116 115 867B
Keysight U1233A U1232A U1273AX U1273A U1272A U1271 U1281 U1282 U1241B U1242B
A continuous tone for a short only:
UNI-T UT61E
UNI-T UT71 UT181A (adjustable mV threshold)
Gossen MetraHit 29S 28S 26S/M (adjustable mV threshold)
Hioki DT4282 DT4281 DT4252 DT4253 DT4256 (adjustable mV threshold and LCD red light)
Voltcraft VC890 VC880 (adjustable mV threshold)
Appa 305 (adjustable mV threshold)
Protek 608 (adjustable mV threshold)
« Last Edit: September 29, 2020, 10:33:08 am by Wytnucls »
The following users thanked this post: 2X, Tedmarsgo
Offline ah_l
« Reply #14 on: April 07, 2017, 12:45:15 pm »
I'm also interested in diode check beeping function. So just to make it clear - does BM235 has a beep on good PN junction?
If not, can anyone suggest a meter  in similar price range which does?
Keysight and Fluke options are a bit out of my range.
Offline BMack
« Reply #15 on: April 12, 2017, 05:33:11 am »
Fluke 289 287 87V 233 179 177 175 117 116 115 77IV 73III 83 110(Old USA model, presumably 111 and 112 also) 12(Old, presumably the 11 as well) 27/FM
UNI-T UT61E
added to Fluke.
The following users thanked this post: Electro Detective
« Reply #16 on: April 12, 2017, 05:57:40 am »
Yes I'll second the Fluke 12 doing the "beep" so 10 and 11 will as they have the same board in them
I found a Fleabay seller in China selling what is supposed to the correct part number of the Fluke 12 LCD display so I've decided to gamble US $35 to see if it's legit and I can resurrect my broken one (sorry can't find a fingers crossed smiley)
Offline TheAmmoniacal
  • Country: no
« Reply #17 on: April 12, 2017, 06:50:02 am »
I am confused, what are the benefits of beeping on ~<0.1V vs. beeping on ~<15 ohm?
« Reply #18 on: April 12, 2017, 07:09:43 am »
What do you normally use to check semiconductors, diode or continuity?
Do you ever work in the field where you need to focus on where your probes are placed and not the screen and you might find it useful, same for the short beep on a good junction.
« Last Edit: April 12, 2017, 07:12:29 am by noidea »
  • Country: no
« Reply #19 on: April 12, 2017, 07:24:53 am »
I see, I got the impression you used it for continuity testing. If you need to repeatedly verify the forward voltage range of a semiconductor without being able to see the DMM screen, an audible buzzer would be useful.
Offline ah_l
« Reply #20 on: July 31, 2017, 09:58:35 am »
To continue with the "mysterious" PN junction beep function in diode test mode. - Does anyone know any low to mid price meter with this functionality?
I love to use it to verify solder connections of hand soldered smd chip pads, but am hesitant to buy high end (200 usd and above) meter just for this.
Maybe someone has a suggestion for other instrument/technique to check whether the chip pads have successfully soldered? - especially for packages such as LGA, where visual inspection is not possible.
Online coromonadalix
« Reply #21 on: July 31, 2017, 10:51:53 am »
The thing i liked the most on my old Beckman Industrial HD160 4000 count dmm, was a tone following the read value, in every function ...  1v gave around a 1khz of audible signal, that way no needs to have eyes on the meter
It was very efficient for intermittent contacts or pulses ... nothing in recent meters came close to that, I had too an old FieldPiece hb7x model who came close ...
On my Gossen 28s, you have to call the "bip function ( threshold)"  otherwise it wont make a sound by default.
Offline kasone
« Reply #22 on: July 31, 2017, 12:53:55 pm »
Fluke 113, 115, & 117 have the diode test beep function that you are looking for.
There are many older used Flukes(76, 77, 73, 27fm, etc) that have this same diode test beep function.
I do not know what country you are from, but you can check local pricing to determine if it is reasonable.
Offline ah_l
« Reply #23 on: August 03, 2017, 11:38:12 am »
Well, in the end I decided that its about time to get at least one decent multimeter anyway, so I went for Keysight U1242b. It made sense price/performance wise compared to low end Flukes (like 115 or 117) that are similarly priced, but lack low range amp measurements which are from time to time required in my work.
I have previously worked quite a lot with high end of this series (U1252b) and liked it a lot. U1242b at least on the surface seems identical quality and usability wise (lower counts and accuracy for U1242b of course).
My beloved diode beep function works like a charm. :)
Offline xavier60
« Reply #24 on: October 23, 2019, 10:07:09 am »
My new BM857s arrived this morning.
It hadn't occurred to me that there would be no beeps on the diode test range.
Because of this inexcusable oversight and the ridiculously difficult to rotate range selector, this meter will not be permanently taking the place of my 87V on the bench.
« Last Edit: October 23, 2019, 10:10:11 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
