Author Topic: R&S CMU200 and CRTU-RU identity recovery  (Read 2176 times)
Offline hafrseTopic starter
« on: December 14, 2018, 12:59:46 pm »
Hello,
I have a CMU200 and a CRTU-RU. The CRTU-RU stopped booting , no bios information etc... Suspected a CPU problem. I replaced the front panel (including the CPU board ) of my CRTU-RU with my CMU200 but using the disk from the CRTU-RU. Booted as version 4.34 and all ok again, I can see that the identity is CRTU-RU with the correct serial number. all oK.
Now to the problem:
I replaced  back the cmu200 front panel  to my CMU200. Booted with the CMU200 hard disk, system but surprisingly started as a CRTU-RU unit with version 5.21 instead of a CMU200 !!!! all options from the CMU are not recognized since they are not CRTU options... Also , I have never seen a CRTU-RU with version 5.21....
I performed a software update using "Software Update After Board replacement" , same problem, it still give me system CRTU-RU and the serial number from the CRTU-RU and not from the CMU200!
It seems that the CMU200 is infected by my procedure above....
where is this informtion about the system if it is a CRTU-RU or CMU-200 and the serial number?  and how can I recover?
man thanks in advanc!
Goerge
« Last Edit: December 14, 2018, 01:12:14 pm by hafrse »
Offline CJay
Re: R&S CMU200 and CRTU-RU identity recovery
« Reply #1 on: December 14, 2018, 02:03:25 pm »
Clear the BIOS and see if that helps
« Reply #2 on: December 14, 2018, 02:16:57 pm »
I have attached a keyboard to the CMU200 and did a Load CMU defaults from the BIOS menu, did not help.
Thanks
« Reply #3 on: December 14, 2018, 02:30:27 pm »
I also checkd the Identity.dat file, it still says CMU:
/************************* CMU IDENTITY ************************/
GENERAL INFORMATION
Serial number: 109xxx/002
CPU and memory:
CPU (FMR)       FMR6
Memory          256 MB
BSW/FSW         V5.01
Statistics data:
Firmware versions:
RXTX_1 CP-SW    08.50, 2006-05-02
Available options:
rxtx1                V8.50    02.05.06
PMGR_RX_DSP_1
PMGR_TX_DSP_1
PMGR_AUDIO_DSP
AUXTX_1
AUXTX_2
CMU-B21Var14
CMU-B56Var14
CMU-B54Var14
COPROC
COPROC_FULL           3.04
CMU-B83           X3.24m (Var. 22)
CMU-B89           Rev. 1
CMU-B52Var14
CMU-B53Var14
CMU-B21
2G_Signalling
Speechcoder
Bluetooth
CMU-B66           included in B68
CMU-B76           included in B78
DIG
DIG_HWC           HWC: 4
DIG_FM
ADC 1
Offline CJay
« Reply #4 on: December 14, 2018, 02:55:22 pm »
Does the serial number match the CMU200 or is it the serial number from the CRTU-RU?
« Reply #5 on: December 14, 2018, 03:09:45 pm »
Hello,
no, it is the serial number from the CRTU-RU. I suspect that the digital board (A7) is holding this information now in my CMU but do not know how to revert to the CMU identity.
Thanks
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #6 on: December 14, 2018, 05:17:54 pm »
Check "list software" in the debug menu. Perhaps one of the older versions is not affected?
« Reply #7 on: December 14, 2018, 07:27:56 pm »
Tried that too, switched software version, same problem. I also tried to build a new HD image from an image file I created a time ago from my working CMU200,  same problem. System is CRTU-RU .
Thanks
Offline Qw3rtzuiop
« Reply #8 on: December 15, 2018, 12:17:24 pm »
I experienced a similar problem. The serial number must be stored somewhere on the FMR. Maybe on one of the EEPROMS.
« Reply #9 on: December 15, 2018, 12:37:32 pm »
Hello,
I have replaced the FMR 6 board with one I had before from a working  CMU200 (spare part) but did not help, this CPU starts now as a CRTU-RU. I suspect the digital board(A7)  runs now as a CRTU system after the original CMU200 was in the CRTU-RU for test reasons.
Thanks
