But wait, there's more! Now how much would you pay? This beast has an ugly sister; she's a bit rustier and has a thin crack in the meter lens in the area above the movement.
Once I get a chance to test the internals, I'll be putting ugly sister up in the B/S/T. I'm just keeping the pics here for now. SOLD to a fellow TEA addict who was quick on the draw. And here's the back on ugly sister; someone has drilled and installed grommets. I BELIEVE this is the one I've actually used.
Here she is wired for testing with a 1KW Evaporative Heater as a load.
Here she is holding and humming a little at 6A/633W.
Here she is barely holding at 10.5A/1363W/150% overload - typically this breaker should trip within an hour or so at that loading. It starts to buzz after ~10 seconds and will trip if you just touch it.
It trips instantly at any of these loads if I short-circuit the output, so I'm gonna say she's fit as a fiddle & ready for love.
Cheers,
*Juicy*
