Author Topic: (WTB UK) Velleman K7103 Oscilloscope Kit Floppies or Assembly Manual PDF Wanted  (Read 1105 times)
Offline Chris56000Topic starter
Hi!
I won a mint unbuilt n.o.s. Velleman K7103 2 Ch Oscilloscope Kit whuch was delivered this morning, the kit contained a blue slip of paper with a big print warning that the Assembly Manual and Software were supplied on the enclosed disks, unfortunately they were missing !
Has anybody got these two floppies they no longer need to pass on to me please?
Failing that, if anyone knows where I can get the files, I'd be very grateful, Velleman deleted them years ago!
The files were the K7103 PDF Assembly Manual and WinDSO_fg32 V1.32!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Online Fraser
The Wayback machine may be able to help you. velleman used to be www.velleman.be so I looked on the Wayback machine and there seems to be a good capture. I have not tested the download links though.
https://web.archive.org/web/20000510203024/http://www.velleman.be/index2.htm
Update: I just tested the download links. Sadly no files on the captures I tried but try others in differnt years, you may get lucky.
Fraser
« Last Edit: July 19, 2021, 12:10:39 pm by Fraser »
Online Fraser
Parts list is to be found here so you could, at least assemble the unit from this......
https://www.circuitspecialists.com/k7103.html
The K7103 Schematic is to be found in the user manual that is still available on the Velleman web site.
https://www.velleman.eu/products/view/?id=9368&country=us&lang=en
Now it is a case of finding the software.
Online Fraser
Have you contacted velleman ? They are usually very helpful and were still supplying the software to those needing it in 2017. The software was used on several differnt scopes so may still be available. Ask fo the test software and assembly manual as well.
https://forum.whadda.com/t/support-for-2-channel-velleman-pc-storage-oscilloscope-32ms/14477/4
Fraser
