« Reply #22 on: November 22, 2020, 03:30:02 pm »
I did some testing on my BM869s and it seems that there are still some capacitive and inductive input problems. I used a resistance decades and I varied values between 510K-600K, it seems that these areas are the most affected. I used different cables, some shielded and others I shielded myself, in vain, the defect (anomaly) did not disappear. But to shorten the discussion I will tell you what I managed to get after a few hours of testing. I put a capacitor with a value of 47nF - 100nF at the input of BM869s and the device became very stable regardless of the position of the cables or the touch with my hand of its active parts or of the resistive decade. (First, I made measurements in Manual Mode and here it seems to be fine).
Logged
Tektronix DMM4050, FLUKE 185, FLUKE 83 V, FLUKE 17B+, BRYMEN BM869s, BM235, BM857, Rigol DS1052E, Rigol DG1022, ANENG AN8008, Uni-T UT07B, UT18C, UT20B, UT116C, UT118B, UT120C, UT123T, UT131A, UT210E, UT658, HUNG CHANG HC-81, HUNG CHANG DM27.
