Author Topic: Evaluation of the oscilloscope ATTEN ads 1102 cal +  (Read 2088 times)
Offline naldoTopic starter
  • Country: br
« on: February 21, 2017, 04:23:51 pm »
Good afternoon everyone! I wonder if this scope is good or bad, what the powders and counter of this appliance.Thank you 1 return!
  • Country: br
Re: Evaluation of the oscilloscope ATTEN ads 1102 cal +
« Reply #1 on: February 22, 2017, 01:19:43 am »
Any tips ??
Offline kcbrown
« Reply #2 on: February 22, 2017, 02:14:42 am »
It looks the same as the Siglent SDS-1102CML.  For the money, you'll probably be far better off with the Rigol DS-1054Z or the GW Instek GDS-1054B (if you need 4 channels and can live with 50MHz maximum bandwidth) or the GW Instek GDS-1102B (if you need 100MHz and can live with 2 channels).
What will you be using the scope primarily for?
The following users thanked this post: naldo
  • Country: br
« Reply #3 on: February 22, 2017, 02:35:15 am »
Thanks for the feedback, I will use it for fine screen tvs repair (lcd, led, etc ...), I have already purchased this scope.
Offline kcbrown
« Reply #4 on: February 22, 2017, 03:25:50 am »
Oh, well, then enjoy!   For your use, it might suit you quite well.
